Libre Office, is there a way to hide unwanted fonts?
    Hi everyone,
    I'm finding that scrolling through the hundreds of fonts in Libre Office interrupts my work flow. Is there any way to hide or remove the many that aren't useful? Eg. arabic/thai/malay etc which I'll never personally use. If I can narrow down the fonts to ones that are relevant it would save so much time !
    In terms of using unbuntu/kubuntu, I've been using them for years, but in terms of programming and using terminal, I'm still Incomputent
    Thank you for reading this far
    Lenovo Thinkpad x230 Core i5vpro, 4G Ram, 320G HDD, Intel HD 4000.
    Running clean install of KUBUNTU 20.04 after years of running Ubuntu 18.04 then a week running Sabayon.
    Running clean install of KUBUNTU 18.04 after a couple of months running ArchLinux Manjaro
    The fonts are what is installed by default in Ubuntu/Kubuntu, so you can use a package manager like Muon or Synaptic and search for font packages, and filter by 'installed' to see what you want to remove. It should be pretty easy to see which ones are for other languages.
    Or go into system settings, and remove them manually from there, tedious for sure.
      This is the command I use to remove fonts I don't need. Your choices may differ:
      sudo apt purge fonts-beng-extra \
      fonts-beng \
      fonts-deva-extra \
      fonts-deva \
      fonts-gargi \
      fonts-gubbi \
      fonts-gujr-extra \
      fonts-gujr \
      fonts-guru-extra \
      fonts-guru \
      fonts-indic \
      fonts-kacst-one \
      fonts-kacst \
      fonts-kalapi \
      fonts-khmeros-core \
      fonts-knda \
      fonts-lao \
      fonts-lklug-sinhala \
      fonts-lohit-beng-assamese \
      fonts-lohit-beng-bengali \
      fonts-lohit-deva \
      fonts-lohit-gujr \
      fonts-lohit-guru \
      fonts-lohit-knda \
      fonts-lohit-mlym \
      fonts-lohit-orya \
      fonts-lohit-taml-classical \
      fonts-lohit-taml \
      fonts-lohit-telu \
      fonts-mlym \
      fonts-nakula \
      fonts-navilu \
      fonts-orya-extra \
      fonts-orya \
      fonts-pagul \
      fonts-sahadeva \
      fonts-samyak-deva \
      fonts-samyak-gujr \
      fonts-samyak-mlym \
      fonts-samyak-taml \
      fonts-sarai \
      fonts-sil-abyssinica \
      fonts-sil-padauk \
      fonts-smc-anjalioldlipi \
      fonts-smc-chilanka \
      fonts-smc-dyuthi \
      fonts-smc-gayathri \
      fonts-smc-karumbi \
      fonts-smc-keraleeyam \
      fonts-smc-manjari \
      fonts-smc-meera \
      fonts-smc-rachana \
      fonts-smc-raghumalayalamsans \
      fonts-smc-suruma \
      fonts-smc-uroob \
      fonts-smc \
      fonts-taml \
      fonts-telu-extra \
      fonts-telu \
      fonts-thai-tlwg \
      fonts-tibetan-machine \
      fonts-tlwg-garuda-ttf \
      fonts-tlwg-garuda \
      fonts-tlwg-kinnari-ttf \
      fonts-tlwg-kinnari \
      fonts-tlwg-laksaman-ttf \
      fonts-tlwg-laksaman \
      fonts-tlwg-loma-ttf \
      fonts-tlwg-loma \
      fonts-tlwg-mono-ttf \
      fonts-tlwg-mono \
      fonts-tlwg-norasi-ttf \
      fonts-tlwg-norasi \
      fonts-tlwg-purisa-ttf \
      fonts-tlwg-purisa \
      fonts-tlwg-sawasdee-ttf \
      fonts-tlwg-sawasdee \
      fonts-tlwg-typewriter-ttf \
      fonts-tlwg-typewriter \
      fonts-tlwg-typist-ttf \
      fonts-tlwg-typist \
      fonts-tlwg-typo-ttf \
      fonts-tlwg-typo \
      fonts-tlwg-umpush-ttf \
      fonts-tlwg-umpush \
      fonts-tlwg-waree-ttf \
      fonts-tlwg-waree \
      fonts-yrsa-rasa
      Kubuntu 20.04
