Hi, is there any keyboard shortcut available to open the " System Settings " ? Thanks.
Keyboard shortcut for System settings
Tags: None
Thanks @chimak111. " Custom shortcut " option came to rescue.
@jglen I need a solution as I have to deal with a failing monitor and a tricky secondary display.
Since KScreen2 is too buggy with annoying popups, I turned it off.
My only option to things going well if my screen fails is to run Kscreen2 through system settings and then give full display to secondary display.
But I do not see the K-Menu when I use the secondary display. If I have shortcut, I can summon the " System Settings " GUI and then run KScreen2 from it. Thanks for the answer.
