Power saving/Poweredevil seems to be malfunction
    Hello,
    No matter what changes I make in Power Savings, they/it don't apply for some reason. Same things happens also in Manjaro Plasma when I was using it. It complaining about a shared library which I can't find in the repositories.
    regards
    Storm
    This is what I get from output:
    storm@universe:~$ systemsettings5
    QQmlEngine::setContextForObject(): Object already has a QQmlContext
    Couldn't load plugin: "The shared library was not found."
    powerdevil: ("AC", "Battery", "migration", "LowBattery") ()
    powerdevil: "Wireless"  has a runtime requirement
    powerdevil: "Screen brightness"  has a runtime requirement
    powerdevil: The action  QVariant(QString, "BrightnessControl")  appears not to be supported by the core.
    powerdevil: "Dim screen"  has a runtime requirement
    powerdevil: The action  QVariant(QString, "DimDisplay")  appears not to be supported by the core.
    powerdevil: "Keyboard backlight"  has a runtime requirement
    powerdevil: The action  QVariant(QString, "KeyboardBrightnessControl")  appears not to be supported by the core.
    powerdevil: "Button events handling"  has a runtime requirement
    powerdevil: "Screen Energy Saving"  has a runtime requirement
    powerdevil: Loading routine called
    powerdevil: ()
    powerdevil: Ok, KConfigGroup ready ("icon")
    powerdevil: ()
    powerdevil: ()
    My System:
     storm@universe:~$ inxi -Fxzc0
    System:
     Kernel: 5.4.0-40-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
     Desktop: KDE Plasma 5.18.5 Distro: Ubuntu 20.04 LTS (Focal Fossa)
    Machine:
     Type: Desktop Mobo: ASUSTeK model: PRIME X370-A v: Rev X.0x serial: <filter>
     UEFI: American Megatrends v: 0805 date: 06/20/2017
    Battery:
     Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750 charge: 93%
     status: N/A
     Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus M705
     charge: 55% (should be ignored) status: Discharging
    CPU:
     Topology: 8-Core model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen rev: 1
     L2 cache: 4096 KiB
     flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
     bogomips: 108583
     Speed: 2030 MHz min/max: 2200/3400 MHz Core speeds (MHz): 1: 1892 2: 1815 3: 2015
     4: 2029 5: 1824 6: 1742 7: 2683 8: 3493 9: 1853 10: 2141 11: 2108 12: 2142 13: 1865
     14: 1767 15: 1849 16: 1819
    Graphics:
     Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia v: 440.100
     bus ID: 2a:00.0
     Display: x11 server: X.Org 1.20.8 driver: nvidia
     unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
     OpenGL: renderer: GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100
     direct render: Yes
    Audio:
     Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
     v: kernel bus ID: 2a:00.1
     Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
     bus ID: 2c:00.3
     Sound Server: ALSA v: k5.4.0-40-generic
    Network:
     Device-1: Qualcomm Atheros AR9227 Wireless Network Adapter driver: ath9k v: kernel
     bus ID: 27:01.0
     IF: wlp39s1 state: up mac: <filter>
     Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
     driver: r8169 v: kernel port: f000 bus ID: 28:00.0
     IF: enp40s0 state: down mac: <filter>
    Drives:
     Local Storage: total: 1.14 TiB used: 61.12 GiB (5.2%)
     ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
     ID-2: /dev/sdb vendor: Toshiba model: DT01ACA100 size: 931.51 GiB temp: 42 C
    Partition:
     ID-1: / size: 227.77 GiB used: 10.91 GiB (4.8%) fs: ext4 dev: /dev/sda5
     ID-2: /home size: 915.89 GiB used: 50.20 GiB (5.5%) fs: ext4 dev: /dev/sdb1
    Sensors:
     System Temperatures: cpu: 45.9 C mobo: N/A gpu: nvidia temp: 54 C
     Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
    Info:
     Processes: 334 Uptime: 5h 01m Memory: 31.36 GiB used: 4.61 GiB (14.7%) Init: systemd
     runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.16 inxi: 3.0.38
    storm@universe:~$
    | AMD Ryzen 1700x 3.4 GHz | ASUS PRIME X370-A | 32 GB 2400 Mhz DDR4 |
    | ASUS Nvidia 1070 8 GB | SSD 250 GB | HDD 1 TB |
    My favourite place of all, is the closet in the hall
    Solved it by re-installing kubuntu. No idea what went wrong in the first place.
      I spoke to soon, the problem still persist.
        Maybe try a Bios update? Yours is from 2017, worth looking there:
        https://www.asus.com/us/Motherboards...HelpDesk_BIOS/
        A somewhat recent one shows this:
        Version 5214 2019/09/09 10.27 MBytesPRIME X370-A BIOS 5214
        1.Improve system performance.
        2.Update AM4 Combo PI 1.0.0.3 Patch ABB
        a.Fixes a compatibility issue with Destiny 2
        b.Fixes an issue with certain Linux distros
        c.Removes Gen 4 support when using Ryzen 3000 CPUs
        3.Improves EZFlash performance to reduce boot time.
        These lines don't mean anything is wrong. I have these on both my laptop and PC, all have fully working power saving settings.
        I also have the missing plugin line, though my laptop is 20.04, running Neon, so it has a newer Plasma. I get extra info that may be relevant.and simply not showing on Kubuntu
        Note that this message is neither a warning nor an error -simply informational.
        Couldn't load plugin "kcms/kcm_powerdevilprofilesconfig" : "The shared library was not found." [B] -- falling back to old-style loading from desktop file[/B]
        I get the same exact output on my 18.04 based Neon PC.
        TMI time:
        The 'missing library' is related to the GUI for the power management section of System Settings, and not the actual power saving settings itself. System Settings is looking for 'kcm_powerdevilprofilesconfig'
        but that does not exist, so a Desktop file is called to open it instead (/usr/share/kservices5/powerdevilprofilesconfig.desktop)
        so instead of kcmshell5 kcm_powerdevilprofilesconfig, it finds the desktop file, and calls it with kcmshell5 powerdevilprofilesconfig
          Thanks. So a BIOS upgrade will do it.
            BIOS updated, but the power saving issue is still there.
              Could you please mention the particular setting(s) so we can take a look?
              BTW, with inxi,
              I think c0 is no longer necessary
              and
              inxi -Fxxxz will provide more information than the code you used in the first post. In general, newer versions of inxi support xxx and searching man inxi for --extra 3 will provide more information.
              Kubuntu 20.04
                Sorry old habits die hard;
                storm@universe:~$ inxi -Fxxxz --extra 3
                System:
                 Desktop: KDE Plasma 5.18.5 tk: Qt 5.12.8 info: latte-dock wm: kwin_x11 dm: SDDM
                Machine:
                 UEFI: American Megatrends v: 5222 date: 10/15/2019
                Battery:
                 serial: <filter> charge: 86% rechargeable: yes status: Charging
                 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
                 status: Discharging
                CPU:
                 L2 cache: 4096 KiB
                 bogomips: 108580
                 Speed: 3197 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz): 1: 3197
                 2: 1953 3: 3021 4: 1887 5: 1882 6: 1907 7: 3215 8: 1925 9: 2317 10: 2191 11: 2018
                 12: 1842 13: 2279 14: 1895 15: 2331 16: 2269
                Graphics:
                 bus ID: 09:00.0 chip ID: 10de:1b81
                 unloaded: fbdev,modesetting,nouveau,vesa compositor: kwin_x11
                 direct render: Yes
                Audio:
                 v: kernel bus ID: 09:00.1 chip ID: 10de:10f0
                 bus ID: 0b:00.3 chip ID: 1022:1457
                Network:
                 bus ID: 06:01.0 chip ID: 168c:002d
                 IF: wlp6s1 state: down mac: <filter>
                 driver: r8169 v: kernel port: f000 bus ID: 07:00.0 chip ID: 10ec:8168
                 IF: enp7s0 state: down mac: <filter>
                Drives:
                 Local Storage: total: 1.14 TiB used: 17.13 GiB (1.5%)
                 speed: 6.0 Gb/s serial: <filter> rev: 2B6Q scheme: MBR
                 ID-2: /dev/sdb vendor: Toshiba model: DT01ACA100 size: 931.51 GiB speed: 6.0 Gb/s
                 rotation: 7200 rpm serial: <filter> rev: A750 temp: 41 C scheme: GPT
                Partition:
                 ID-1: / size: 227.77 GiB used: 10.42 GiB (4.6%) fs: ext4 dev: /dev/sda5
                 ID-2: /home size: 915.89 GiB used: 6.70 GiB (0.7%) fs: ext4 dev: /dev/sdb1
                Sensors:
                 System Temperatures: cpu: 53.4 C mobo: N/A gpu: nvidia temp: 52 C
                Info:
                 Processes: 347 Uptime: 1h 39m Memory: 31.36 GiB used: 5.27 GiB (16.8%) Init: systemd
                 v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Shell: bash v: 5.0.16
                 running in: konsole inxi: 3.0.38
                storm@universe:~$
                The thing is I want to disable power savings.
