First of all, I hope to express myself well, I think the best thing will be to make a short video and it will be easier to understand (especially because of my bad English ..
Since 2019 I use the same hardware and graphics card AMD R5 230 1GB Ram ...
Everything good, everything perfect.
1 year ago I added a second monitor, I configure both with the same panel, not a mirror screen, and each panel, in its properties, I configure it to only show the tasks of that screen.
Perfect, in Monitor 1 I have, for example, browser 1, 2 and 3, and in Monitor 2 I have browser 4, 5 and 6.
Perfect, I turn off monitor 2 (which is the one connected by hdmi), and when I turn it on again, everything remains as it was (turn off monitor I mean turn off monitor, not pc), even monitor 2 switch to vga (vga is connected to work laptop ) and when I go back to hdmi it keeps showing me everything as it was (pc on). Brilliant! It's how I wish it works.
Well, a few days ago, I bought a second hand AMD RX 550 4GB Ram graphics card. It is second hand but visually it looks almost new ...
Here the behavior changes radically.
I configure again, both screens do not screen mirror, each screen with its own panel, configured the same as before, that only shows the tasks of the current screen (or what is the same, of its screen).
Well, if I suspend the pc (sleep mode) but I do NOT turn off monitors, when resuming everything remains the same but ... if I turn off monitor B (it is the monitor connected by hdmi) I leave monitor A on, it shows monitor A content, but in the moment to turn on Monitor B .... the image of monitor A begins to make a strange image and suddenly, everything is in both monitors, like a screen mirror but without being a mirror, because the mouse moves independently.
I open a new window in Monitor B (dolphin for example) I minimize ... it has disappeared !!! I open dolphin again and it detects there is another one open because now it shows me dolphin (2) .....
The same happens if I am with both monitors, I switch monitor B from hdmi to vga (work laptop) and when I return to hdmi, the same thing happens to me as if I turn the monitor off and on.
Thinking it might be some residual configuration, I have tried kubuntu 20.04.03 in live mode, and it does the exact same thing to me ...
For example, in this post the user claydoh indicate:
And this is my config and works fine with my "old" graphic card, but not work the same with my "new" graphic card (also AMD) and always use stock drivers.
At this point, I don't know what to think ... possible defect in the hdmi port of the graphics? Any config in bios? Any config that escapes me on the system?
For me it is very strange, two amd graphics cards, the same system and the same hardware, different behaviors in front of two monitors with two panels configured so that each one shows only the current tasks of that monitor.
Forgive this long post, if you see it, a good idea, I'll make a little video and put it on and it will look better.
Thank you all!
Edit: I forgot; My two monitors, same monitors, same models, same resolutions...
The only way to have identical panels on each monitor (without having mirrored screens) is to create one on the new monitor by adding a new default panel -- right click on the desktop and then Add Panel >> Default Panel .
Then you can edit the task manager on it to only show applications from only that screen,
Thank you all!
