ubi-partman error 141
    Please help!!!
    Partitioned computers in the past with Kubuntu and never had this problem. I have a new HP with windows 10 and am trying to install Kubuntu 20.04 with dual boot. During the installation process, the "ubi-partman error 141" shows up before the disk setup. Cannot make progress.
    Tried:
    -decrypting bitlocker
    -disabling secure boot
    -creating an unallocated space on the hard drive
    From a live desktop session, can you see your hard drive(s) in the file manager?
    What computer do you have?
    If you cannot see the drive from Dolphin, then likely your computer is using Intel's RST raid setup, which has zero Linux support. You would have to switch to ahci in your bios.
    This will also mean a few steps to make Windows work in this mode before you try installing again:
    https://www.top-password.com/blog/sw...lling-windows/
      claydoh,
      In the BIOS, the setting is AHCI. Still same error.
        Originally posted by Chaimputz View Post
        claydoh,
        But what about this info:
        A Live session is choosing 'Try Kubuntu'. Then you can use the file manager and see if you can see your hard drive.
        And
        Does this mean you have the whole drive encrypted in Windows?
        I admit I am not at all familiar with bitlocker.
        Probably these can be viewed for reference?
        https://itsfoss.com/dual-boot-ubuntu-windows-bitlocker/
        https://discourse.ubuntu.com/t/ubunt...urned-on/15338
        Also, try creating a new USB installer using a different program than the one you used., such as Balena Etcher, maybe even try downloading a fresh ISO image.
