Hi all.
I'm planning to add a new SSD drive to my system and I think I will make a new clean install. So obviously what I want is to install Kubuntu 20.04 in the SSD drive and use the old HDD as a storage unit but I'm not sure if I should have /home folder in the SSD drive or in the old HDD. In fact, right now I'm not sure if it is possible at all to set a second drive as /home during installation...
What would in your opinion be the most suitable setting? The new SSD drive is 256 GB while the old HDD is 1TB.
Now that I'm on it, would it be possible to set /home pointing to the old existing one on the HDD WITHOUT formatting the drive and then just delete all the old system folders in that drive?
Thanks!
Thanks!
