Hello Kubuntu Community,
greetings to all!
I have installed Kubuntu 20.04 on my desktop computer and I have the problem that when I shut down the computer it immediately reboots and is not shutting down properly.
I have tried different configurations with ACPI in the "/etc/default/grub" file, modifying the (GRUB_CMD_LINE_DEFAULT="acpi=force") line, I have also tried more things such as "net.ifnames=0" or (GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=force apm=power_off") but it did not solve my problem.
I have also added in the following line in "/etc/modules" (apm power_off=1), then I have updated the grub using the command "sudo update-grub".
I have tried to shutdown from bash using the command "shutdown -P now" but still the same problem. I don't know what to do anymore.
The only way that has worked for me is to press the shutdown button so it won't start up again.
The summary of the information of my computer is the following (with the code "inxi -Fxzd"):
Thanks in advance, I hope you can help me to solve this problem.
Best regards,
JP
greetings to all!
[FONT=monospace][COLOR=#5454ff][B]System: Kernel:[/B][/COLOR][COLOR=#000000] 5.8.0-43-generic x86_64 [/COLOR][COLOR=#5454ff][B]bits:[/B][/COLOR][COLOR=#000000] 64 [/COLOR][COLOR=#5454ff][B]compiler:[/B][/COLOR][COLOR=#000000] N/A [/COLOR][COLOR=#5454ff][B]Desktop:[/B][/COLOR][COLOR=#000000] KDE Plasma 5.18.5 [/COLOR] [COLOR=#5454ff][B]Distro:[/B][/COLOR][COLOR=#000000] Ubuntu 20.04.2 LTS (Focal Fossa) [/COLOR] [COLOR=#5454ff][B]Machine: Type:[/B][/COLOR][COLOR=#000000] Desktop [/COLOR][COLOR=#5454ff][B]Mobo:[/B][/COLOR][COLOR=#000000] Intel [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] DZ77GA-70K [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] AAG39009-400 [/COLOR][COLOR=#5454ff][B]serial:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR][COLOR=#5454ff][B]BIOS:[/B][/COLOR][COLOR=#000000] Intel [/COLOR] [COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] GAZ7711H.86A.0066.2013.0521.1509 [/COLOR][COLOR=#5454ff][B]date:[/B][/COLOR][COLOR=#000000] 05/21/2013 [/COLOR] [COLOR=#5454ff][B]Battery: Device-1:[/B][/COLOR][COLOR=#000000] hidpp_battery_0 [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] Logitech Wireless Keyboard [/COLOR][COLOR=#5454ff][B]charge:[/B][/COLOR][COLOR=#000000] 55% (should be ignored) [/COLOR] [COLOR=#5454ff][B]status:[/B][/COLOR][COLOR=#000000] Discharging [/COLOR] [COLOR=#5454ff][B]CPU: Topology:[/B][/COLOR][COLOR=#000000] Quad Core [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] Intel Core i7-3770K [/COLOR][COLOR=#5454ff][B]bits:[/B][/COLOR][COLOR=#000000] 64 [/COLOR][COLOR=#5454ff][B]type:[/B][/COLOR][COLOR=#000000] MT MCP [/COLOR][COLOR=#5454ff][B]arch:[/B][/COLOR][COLOR=#000000] Ivy Bridge [/COLOR][COLOR=#5454ff][B]rev:[/B][/COLOR][COLOR=#000000] 9 [/COLOR] [COLOR=#5454ff][B]L2 cache:[/B][/COLOR][COLOR=#000000] 8192 KiB [/COLOR] [COLOR=#5454ff][B]flags:[/B][/COLOR][COLOR=#000000] avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx [/COLOR][COLOR=#5454ff][B]bogomips:[/B][/COLOR][COLOR=#000000] 55873 [/COLOR] [COLOR=#5454ff][B]Speed:[/B][/COLOR][COLOR=#000000] 1696 MHz [/COLOR][COLOR=#5454ff][B]min/max:[/B][/COLOR][COLOR=#000000] 1600/3900 MHz [/COLOR][COLOR=#5454ff][B]Core speeds (MHz):[/B][/COLOR][COLOR=#5454ff][B]1:[/B][/COLOR][COLOR=#000000] 1695 [/COLOR][COLOR=#5454ff][B]2:[/B][/COLOR][COLOR=#000000] 1687 [/COLOR][COLOR=#5454ff][B]3:[/B][/COLOR][COLOR=#000000] 1628 [/COLOR][COLOR=#5454ff][B]4:[/B][/COLOR][COLOR=#000000] 1681 [/COLOR][COLOR=#5454ff][B]5:[/B][/COLOR][COLOR=#000000] 1625 [/COLOR] [COLOR=#5454ff][B]6:[/B][/COLOR][COLOR=#000000] 1608 [/COLOR][COLOR=#5454ff][B]7:[/B][/COLOR][COLOR=#000000] 1696 [/COLOR][COLOR=#5454ff][B]8:[/B][/COLOR][COLOR=#000000] 1640 [/COLOR] [COLOR=#5454ff][B]Graphics: Device-1:[/B][/COLOR][COLOR=#000000] NVIDIA GK208B [GeForce GT 710] [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Gigabyte [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] nvidia [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 460.39 [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 01:00.0 [/COLOR] [COLOR=#5454ff][B]Display:[/B][/COLOR][COLOR=#000000] x11 [/COLOR][COLOR=#5454ff][B]server:[/B][/COLOR][COLOR=#000000] X.Org 1.20.9 [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] nvidia [/COLOR][COLOR=#5454ff][B]resolution:[/B][/COLOR][COLOR=#000000] 1920x1080~60Hz [/COLOR] [COLOR=#5454ff][B]OpenGL:[/B][/COLOR][COLOR=#5454ff][B]renderer:[/B][/COLOR][COLOR=#000000] GeForce GT 710/PCIe/SSE2 [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 4.6.0 NVIDIA 460.39 [/COLOR][COLOR=#5454ff][B]direct render:[/B][/COLOR][COLOR=#000000] Yes [/COLOR] [COLOR=#5454ff][B]Audio: Device-1:[/B][/COLOR][COLOR=#000000] Intel 7 Series/C216 Family High Definition Audio [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] snd_hda_intel [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR] [COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 00:1b.0 [/COLOR] [COLOR=#5454ff][B]Device-2:[/B][/COLOR][COLOR=#000000] NVIDIA GK208 HDMI/DP Audio [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Gigabyte [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] snd_hda_intel [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR] [COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 01:00.1 [/COLOR] [COLOR=#5454ff][B]Sound Server:[/B][/COLOR][COLOR=#000000] ALSA [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] k5.8.0-43-generic [/COLOR] [COLOR=#5454ff][B]Network: Device-1:[/B][/COLOR][COLOR=#000000] Intel 82579V Gigabit Network [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] e1000e [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 3.2.6-k [/COLOR][COLOR=#5454ff][B]port:[/B][/COLOR][COLOR=#000000] f040 [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 00:19.0 [/COLOR] [COLOR=#5454ff][B]IF:[/B][/COLOR][COLOR=#000000] eno1 [/COLOR][COLOR=#5454ff][B]state:[/B][/COLOR][COLOR=#000000] down [/COLOR][COLOR=#5454ff][B]mac:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR] [COLOR=#5454ff][B]Device-2:[/B][/COLOR][COLOR=#000000] Intel 82574L Gigabit Network [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] e1000e [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 3.2.6-k [/COLOR][COLOR=#5454ff][B]port:[/B][/COLOR][COLOR=#000000] d000 [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 03:00.0 [/COLOR] [COLOR=#5454ff][B]IF:[/B][/COLOR][COLOR=#000000] eth1 [/COLOR][COLOR=#5454ff][B]state:[/B][/COLOR][COLOR=#000000] down [/COLOR][COLOR=#5454ff][B]mac:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR] [COLOR=#5454ff][B]Device-3:[/B][/COLOR][COLOR=#000000] Intel Wi-Fi 6 AX200 [/COLOR][COLOR=#5454ff][B]driver:[/B][/COLOR][COLOR=#000000] iwlwifi [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] kernel [/COLOR][COLOR=#5454ff][B]port:[/B][/COLOR][COLOR=#000000] d000 [/COLOR][COLOR=#5454ff][B]bus ID:[/B][/COLOR][COLOR=#000000] 06:00.0 [/COLOR] [COLOR=#5454ff][B]IF:[/B][/COLOR][COLOR=#000000] wlp6s0 [/COLOR][COLOR=#5454ff][B]state:[/B][/COLOR][COLOR=#000000] up [/COLOR][COLOR=#5454ff][B]mac:[/B][/COLOR][COLOR=#000000] <filter> [/COLOR] [COLOR=#5454ff][B]Drives: Local Storage:[/B][/COLOR][COLOR=#5454ff][B]total:[/B][/COLOR][COLOR=#000000] 2.84 TiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 37.04 GiB (1.3%) [/COLOR] [COLOR=#5454ff][B]ID-1:[/B][/COLOR][COLOR=#000000] /dev/sda [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Kingston [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] SV300S37A120G [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 111.79 GiB [/COLOR] [COLOR=#5454ff][B]ID-2:[/B][/COLOR][COLOR=#000000] /dev/sdb [/COLOR][COLOR=#5454ff][B]vendor:[/B][/COLOR][COLOR=#000000] Western Digital [/COLOR][COLOR=#5454ff][B]model:[/B][/COLOR][COLOR=#000000] WD30EZRX-00DC0B0 [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 2.73 TiB [/COLOR] [COLOR=#5454ff][B]Message:[/B][/COLOR][COLOR=#000000] No Optical or Floppy data was found. [/COLOR] [COLOR=#5454ff][B]Partition: ID-1:[/B][/COLOR][COLOR=#000000] / [/COLOR][COLOR=#5454ff][B]size:[/B][/COLOR][COLOR=#000000] 109.04 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 37.04 GiB (34.0%) [/COLOR][COLOR=#5454ff][B]fs:[/B][/COLOR][COLOR=#000000] ext4 [/COLOR][COLOR=#5454ff][B]dev:[/B][/COLOR][COLOR=#000000] /dev/sda5 [/COLOR] [COLOR=#5454ff][B]Sensors: System Temperatures:[/B][/COLOR][COLOR=#5454ff][B]cpu:[/B][/COLOR][COLOR=#000000] 29.8 C [/COLOR][COLOR=#5454ff][B]mobo:[/B][/COLOR][COLOR=#000000] 28.0 C [/COLOR][COLOR=#5454ff][B]gpu:[/B][/COLOR][COLOR=#000000] nvidia [/COLOR][COLOR=#5454ff][B]temp:[/B][/COLOR][COLOR=#000000] 36 C [/COLOR] [COLOR=#5454ff][B]Fan Speeds (RPM):[/B][/COLOR][COLOR=#000000] N/A [/COLOR][COLOR=#5454ff][B]gpu:[/B][/COLOR][COLOR=#000000] nvidia [/COLOR][COLOR=#5454ff][B]fan:[/B][/COLOR][COLOR=#000000] 0% [/COLOR] [COLOR=#5454ff][B]Info: Processes:[/B][/COLOR][COLOR=#000000] 275 [/COLOR][COLOR=#5454ff][B]Uptime:[/B][/COLOR][COLOR=#000000] 34m [/COLOR][COLOR=#5454ff][B]Memory:[/B][/COLOR][COLOR=#000000] 23.46 GiB [/COLOR][COLOR=#5454ff][B]used:[/B][/COLOR][COLOR=#000000] 2.49 GiB (10.6%) [/COLOR][COLOR=#5454ff][B]Init:[/B][/COLOR][COLOR=#000000] systemd [/COLOR][COLOR=#5454ff][B]runlevel:[/B][/COLOR][COLOR=#000000] 5 [/COLOR] [COLOR=#5454ff][B]Compilers:[/B][/COLOR][COLOR=#5454ff][B]gcc:[/B][/COLOR][COLOR=#000000] 9.3.0 [/COLOR][COLOR=#5454ff][B]Shell:[/B][/COLOR][COLOR=#000000] bash [/COLOR][COLOR=#5454ff][B]v:[/B][/COLOR][COLOR=#000000] 5.0.17 [/COLOR][COLOR=#5454ff][B]inxi:[/B][/COLOR][COLOR=#000000] 3.0.38 [/COLOR] [/FONT]
Best regards,
JP
