I recently did a Kubuntu-20.04 x64 LTS, clean install on my Dell-Vostro-3568, i3-6006U, 4GB-RAM. During the installation process, I selected my previous Home partition (from Kubntu-18.04LTS) to be used as the new Home partition and selected "/home" as the mount point (during installation).
So far so good, everything seems to work fine and the home partition is correctly mounted on the "/home" directory. However there is one problem. During installation the system creted a home for my "/home/mohit". And thus, now the linux home parition also has one more partition for my username and it is currently showing in the /home/mohit.
So the problem is that I have got two homes now. The one that is created by the installation process and the one that I selected to be mounted under /home.
I tried to fix this problem by editing the /etc/fstab file and instead of mounting home partition under /home I selected it to be mounted under /home/mohit but that is causing the system to freeze on the login prompt. And I had to drop to the root shell to undo my changes.
Also while doing all this my system now starts to give this additional error some pcie severity corrected error, something like that, however it is not a big problem I will tackle it myself.
The main problem is how to correctly mount the previous partition so that my system has only one home for my username "mohit". I also deleted all the previous hidden / configuration files and system files from the /home partition and only kept my documents and other stuff as those files contained some settings that was causing problem in my previous install of 18.04LTS. I hope deleting those file didn't caused this problem.
NOTE: My linux knowlege is Intermediate, so any instructions you tell, I guess I can manage to follow along.
Thanks in advance
Thanks in advance
