Broken Screen Locker
    Fresh install. Did not install "a ton" of software, but I did install steam. Not sure if the screen locker was broken before that or not. Also, I did install the ampgpu-install package and installed the opencl drivers.
    The screen says, "The screen locker is broken and unlocking is not possible anymore. In order to unlock switch to a virtual terminal (e.g. Ctrl+Alt+F2), log in and execute the command: loginctl unlock-session 3
    Afterwards switch back to the running session.
    Any idea on how to fix the screen locker? This comes up any time that the screen is going to be locked...obviously. I appreciate any help or insight anyone can give.
    Thanks,
    neech
    This usually happens after a large update. Try doing "apt full-upgrade" and rebooting.
