Boot precautions; recommendation?
    I have been using Linux distributions for several years now in my main personal PC. I always have had a partition configuration like this:
    1- Main Linux partition boot
    2- Secondary Linux partition boot
    3- My Data partition
    In 1, currently I have Kubuntu. In 2, I always keep Mint. In 3, is my user's data. A couple of days ago, this partition setup saved me, as the Kernel update failed in partition 1, and I could manage to work under Mint. I later found out that I could work under a previous kernel in partition 1, selecting it from the Grub menu.
    Recently, I installed Kubuntu in a HP zBook 14u G4. The whole HD with Kubuntu, and all is just perfect. So obviously, I don't get into a grub menu in the laptop, as Kubuntu is the only one distro there. But, if I run in a similar situation as in my PC, where the latest kernel fails in the laptop... how can I get to load a previous kernel? is there an FX key I may press to come up with a boot menu and select the kernel I need to boot with? Or should I partition the laptop as I have my PC, in case of a Kubuntu boot contingency?
    Grub is still loading, it's just doing it with a hidden menu. You can un-hide it by changing the defaults or by holding the SHIFT or ESC key during boot. Which one depends on your setup and timing.
    In any case, IMO having a backup distro is never a bad idea if you have the space - jus' sayin'. Never know when you'll bork your system. Alternately, have a bootable USB handy.
      Stabbing the esc key just past the bios/logo splash should bring up the grub menu, tho that is tricky for me if I get the timing wrong, as this also can open my PC's bios menu if I do it too early.
      You can tweak grub to always show, as well, or change the timeout from 0 to a few seconds.
      Grub-customizer should be useful for this.
        I do what you are doing, the whole drive is devoted to Kubuntu. If something goes wrong I'll boot to Knoppix on a USB drive and fix my problems from there. https://www.techrepublic.com/blog/di...-distribution/
          (Note that with a modern PC, there should be a small EFI System Partition.)
          An alternative to another partition for another install, is to use a big btrfs partition, with several installs in it. That way, one doesn't have to juggle space between the different installs, and data directories. Separation is done with subvolumes.
