I can no longer connect to any wired ethernet. I was previously able to connect but it has been increasingly unreliable and now I can't connect at all.
I am pretty naive about networking.
I have a couple of consumer routers and I can't connect to either of them by ethernet wire.
It says "connecting" with the blue spinny then it says "deactivated" and I get the code: enp0s31f6
I can connect to one router via wifi, but I cannot access the router GUI at 192.168.1.1. The other router is not configured yet because I can't get an initial connection.
I have tried using the ethernet port on the computer and on the dock.
Assistance appreciated...
