Discovered that when I use this controller in Kubuntu 20.04 the LED lighting does not work. When I use it in windows-10 it does work. All the controls work fine in both operating systems. I thought the lighting would just be powered by USB power but I guess there is more involved. Searched the web with no luck. Found one article about it but no fix was given. BTW I play games using Steam. Steam has a controller set up but it had nothing about turning on/off the LED lighting. Don't think it's a Steam issue since it works fine in Windows-10 and Steam. My Kubuntu is up to date too. Thoughts?
Ideas?
"lsusb" in terminal lists it as" BDA XB1 Spectra PRO with ID 24c6:592a
Thanks in advance.
link to controller: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Ideas?
Thanks in advance.
