I installed Kubuntu 20.04 last night, without updates. Everything worked fine except for the sound . I ran the updates to see if it would solve the issue, but nothing changed; sound still not working.
After some investigation, I discovered that sound modules are missing for kernel version 5.8.0-36-generic, which is what my Kubuntu 20.04 system is configured to boot by default.
martin@elise:~$ ls /lib/modules/5.8.0-36-generic/kernel/sound/ -l
drwxr-xr-x 3 root root 4096 jan 10 16:15 core
drwxr-xr-x 3 root root 4096 jan 10 16:15 drivers
drwxr-xr-x 2 root root 4096 jan 10 16:15 pci
-rw-r--r-- 1 root root 16969 jan 6 10:31 soundcore.ko
martin@elise:~$
By comparison, if I check the modules of an older kernel version on the system, then I find lots more folders and modules:
martin@elise:~$ ls /lib/modules/5.4.0-60-generic/kernel/sound/ -l
total 76
-rw-r--r-- 1 root root 6889 jan 5 17:51 ac97_bus.ko
drwxr-xr-x 4 root root 4096 jan 10 16:14 core
drwxr-xr-x 6 root root 4096 jan 10 16:14 drivers
drwxr-xr-x 10 root root 4096 jan 10 16:14 firewire
drwxr-xr-x 3 root root 4096 jan 10 16:14 hda
drwxr-xr-x 3 root root 4096 jan 10 16:14 i2c
drwxr-xr-x 3 root root 4096 jan 10 16:14 isa
drwxr-xr-x 26 root root 4096 jan 10 16:14 pci
drwxr-xr-x 4 root root 4096 jan 10 16:14 pcmcia
drwxr-xr-x 14 root root 4096 jan 10 16:14 soc
-rw-r--r-- 1 root root 16313 jan 5 17:51 soundcore.ko
drwxr-xr-x 3 root root 4096 jan 10 16:14 synth
drwxr-xr-x 9 root root 4096 jan 10 16:14 usb
drwxr-xr-x 2 root root 4096 jan 10 16:14 x86
drwxr-xr-x 2 root root 4096 jan 10 16:14 xen
martin@elise:~$
So I tried rebooting and editing the grub command to load 5.4.0-60-generic instead, and then the sound is working as expected.
But this does not solve my issue on the current/default kernel version.
Thus, I'm wondering if anyone has a suggestion on how to install the missing sound modules for 5.8.0-36-generic?
Thanks!
martin@elise:~$
total 76
martin@elise:~$
Thanks!
