No sound after 20.04 upgrade HDMI / dummy output / snd-hda-intel
    [SOLVED] No sound after 20.04 upgrade HDMI / dummy output / snd-hda-intel
    After upgrade to 20.04 LTS, my soundcard 0 disappeard. This was the HDMI audio output. HDMI audio output was working with 18.04 LTS
    Also, it seems that Plasma/PulseAudio switch to exclusively the "Dummy output" when there's no card at index 0:
    $pacmd list-cards
    0 card(s) available.
    ==> PulseAudio has no card.
    $sudo alsamixer
    cannot open mixer: No such device
    $sudo aplay -l
    **** List of PLAYBACK Hardware Devices ****
    card 1: PCH [HDA Intel PCH], device 0: ALC892 Analog [ALC892 Analog]
    Subdevices: 1/1
    Subdevice #0: subdevice #0
    $sudo cat /proc/asound/cards
    1 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0xf7d10000 irq 33
    ==> So, I have at least one sound card, the Analog one. It's good to have it in index 1 since anyway I use HDMI output, and HDMI should be at index 0 (but missing)
    $sudo alsamixer -c 1
    ==>Works on the analog sound card.
    $lspci -v | grep -A6 -i audio
    00:03.0 Audio device: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller (rev 06)
    Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
    Flags: fast devsel, IRQ 16
    Memory at f7d14000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: <access denied>
    Kernel driver in use: snd_hda_intel
    Kernel modules: snd_hda_intel
    00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
    Subsystem: Micro-Star International Co., Ltd. [MSI] 8 Series/C220 Series Chipset High Definition Audio Controller
    Flags: bus master, fast devsel, latency 0, IRQ 33
    Memory at f7d10000 (64-bit, non-prefetchable) [size=16K]
    ==> So I have 2 sound cards, best guess is that one of the 2 is the HDMI output. Both have the driver loaded.
    $cat /proc/asound/card*/codec* | grep Codec
    Codec: Realtek ALC892
    I did try:
    $sudo apt remove --purge alsa-base pulseaudio
    $sudo apt install alsa-base pulseaudio
    $sudo alsa force-reload
    But problem is still there. Dummy output and no HDMI sound card.
    Any idea ?
    Thanks,
    These links have the most common fixes to this issue.
    As you have an ALC892 the first link may be the most useful
    https://www.linuxuprising.com/2018/0...-issue-in.html
    Read the whole thing, there are a couple of options to try when editing the file as shown.
    This is somewhat similar but has some other things to look at.
    https://medium.com/@aaro.alhainen/ho...e-eaa525838e0d
    Another:
    https://itsfoss.com/fix-sound-ubuntu-1304-quick-tip/
    Option 5 is again similar to the above links, but shows another option when editing the conf file.
    I lean toward the first one, with its two options.
      Thanks claydoh, definitely valuable links.
      The first link did not work as is, I'll continue investigating.
      This makes me discover this inxi excellent command.
      Also, a second problem that I'll try to fix first, since it significantly slower the resolution process:
      After upgrade to 20.04 / Kernel 5.4.0, the computer does not shutdown or reboot any more, but hangs at shutdown.
      Interesting:
      root@homer:~# tail /var/log/kern.log | grep snd_hda_intel
      Nov  4 01:55:46 homer kernel: [   76.552265] snd_hda_intel 0000:00:03.0: couldn't bind with audio component
      Nov  4 01:55:46 homer kernel: [   76.552285] snd_hda_intel 0000:00:03.0: HSW/BDW HD-audio HDMI/DP requires binding with gfx driver
      HW info:
      root@homer:~# inxi -x -A -CGSM -y 160
      System:    Host: homer Kernel: 5.4.0-52-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Console: tty 3 Distro: Ubuntu 20.04.1 LTS (Focal Fossa)
      Machine:   Type: Desktop Mobo: MSI model: Z87-G43 (MS-7816) v: 1.0 serial: N/A BIOS: American Megatrends v: 1.6 date: 11/27/2013
      CPU:       Topology: Quad Core model: Intel Core i7-4770S bits: 64 type: MT MCP arch: Haswell rev: 3 L2 cache: 8192 KiB
               flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 49599
               Speed: 2300 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 2300 2: 2296 3: 2300 4: 2300 5: 2303 6: 2300 7: 2301 8: 2300
      Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI driver: N/A bus ID: 00:02.0
               Display: server: X.org 1.20.8 driver: vesa unloaded: fbdev,modesetting tty: 171x43
               Message: Advanced graphics data unavailable in console for root.
      Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:03.0
               Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1b.0
               Sound Server: ALSA v: k5.4.0-52-generic
      Investigation ongoing...
        First my reboot / shutdown problem. It seems to be fixed by replacing /etc/default/grub with the package maintainer's version. The only difference, is that I had the following additional settings in the previous file:
        GRUB_GFXMODE=1280x720
        GRUB_GFXPAYLOAD_LINUX=1280x720
        The HDMI output:
        I can see my card1 as analog. Did not test it. But the HDMI output is still missing. And I think the following lines are very relevant to my problem:
        grep -E "(HDMI|snd_hda)" /var/log/kern.log
        Nov  4 11:39:23 homer kernel: [    0.140968] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
        Nov  4 11:39:23 homer kernel: [   20.574552] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC892: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
        Nov  4 11:39:23 homer kernel: [   20.574553] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
        Nov  4 11:39:23 homer kernel: [   20.574554] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
        Nov  4 11:39:23 homer kernel: [   20.574555] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
        Nov  4 11:39:23 homer kernel: [   20.574555] snd_hda_codec_realtek hdaudioC1D0:    inputs:
        Nov  4 11:39:23 homer kernel: [   20.574556] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
        Nov  4 11:39:23 homer kernel: [   20.574557] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
        Nov  4 11:39:23 homer kernel: [   20.574558] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
        Nov  4 11:39:23 homer kernel: [   80.964909] snd_hda_intel 0000:00:03.0: couldn't bind with audio component
        Nov  4 11:39:23 homer kernel: [   80.964915] snd_hda_intel 0000:00:03.0: HSW/BDW HD-audio HDMI/DP requires binding with gfx driver
        So, it seems related to the video driver. (My computer has nothing to do with Lenovo)
        But which video driver am I supposed to use for this Intel card ?
        00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])
              DeviceName:  Onboard IGD
              Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
              Flags: bus master, fast devsel, latency 0, IRQ 11
              Memory at f7800000 (64-bit, non-prefetchable) [size=4M]
              Memory at e0000000 (64-bit, prefetchable) [size=256M]
              I/O ports at f000 [size=64]
              Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
              Kernel modules: i915
        Not sure why, but it used by default fbdev which was super slow. So, I removed it : apt remove xserver-xorg-video-fbdev
        Then it falls back to vesa driver :
        Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics driver: N/A
                 Display: x11 server: X.Org 1.20.8 driver: vesa unloaded: modesetting resolution: 1920x1080~N/A
                 OpenGL: renderer: llvmpipe (LLVM 10.0.0 256 bits) v: 3.3 Mesa 20.0.8
        So why is Kubuntu 20.04 not finding and using the intel driver, as it's being reported as an i915 by lspci ?
          i915 is the Intel driver, for most all intel graphics chips.
          fbdev is a driver for the console (pre-boot and non-gui bits)
            The problem is fixed. Thanks to the section
            No sound through HDMI on a Haswell CPU in this link:
            https://wiki.archlinux.org/index.php/intel_graphics
            In my case this was just about setting the GRUB_CMDLINE_LINUX_DEFAULT to "intel_iommu=on,igfx_off":
            root@homer:~# grep ^GRUB_CMD /etc/default/grub
            GRUB_CMDLINE_LINUX_DEFAULT="intel_iommu=on,igfx_off"
            GRUB_CMDLINE_LINUX=""
            After reboot, all inputs from the sound card were immediately available in PulseAudio/Plasma, including the HDMI ones.
            I also noticed that after this kernel parameters change, the X display driver changed to modesetting:
            root@homer:~# inxi -G
            Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics driver: i915 v: kernel
                      Display: server: X.org 1.20.8 driver: modesetting unloaded: vesa tty: 172x43
