I've recently bought a new Asus TUF Gaming A15 laptop which has a HDMI and a USB-c connecter. My setup is as follows:
Laptop: Asus TUF Gaming A15
OS: Kubuntu 20.04
Monitor 1: Laptop screen
Monitor 2: Connected through HDMI
Monitor 3: Connected with a HDMI in a HDMI-USBC-connector in the USB-C port of the laptop
Now the strange thing is that the second monitor on the USB-c is detected, but gives a black screen. The xrandr output is:
This is a screenshot of the Display Configuration.
:fill(white):strip_exif()/f/image/S0P2Rv73kEF01wjr40aQ3gva.png?f=user_large)
All looks good, but the screen just shows a black screen. Whenever I change the resolution of that monitor, for example, it makes these noises it should make when changing the resolution. So something is working. Also the monitor says it gets input, only the input is entirely black. The information page on the monitor itself shows:
:strip_exif()/f/image/x03mOnXMZejd7uU063ItB9AJ.jpg?f=fotoalbum_medium)
On Windows it works just fine.
Anyone got any idea what could be the problem? Many thanks for your reply in advance!
OS: Kubuntu 20.04
[FONT=monospace]Screen 0: minimum 320 x 200, current 6400 x 1440, maximum 16384 x 16384 eDP connected 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm 1920x1080 59.98*+ 1680x1050 59.98 1280x1024 59.98 1440x900 59.98 1280x800 59.98 1280x720 59.98 1024x768 59.98 800x600 59.98 640x480 59.98 HDMI-A-0 connected primary 2560x1440+1920+0 (normal left inverted right x axis y axis) 7 25mm x 428mm 2560x1440 59.95*+ 74.97 1920x1200 59.95 1920x1080 60.00 50.00 59.94 1600x1200 59.95 1280x1440 59.91 1680x1050 59.88 1280x1024 75.02 60.02 1440x900 59.90 1280x960 60.00 1280x800 59.95 1280x720 60.00 50.00 59.94 1024x768 75.03 70.07 60.00 832x624 74.55 800x600 72.19 75.00 60.32 56.25 720x576 50.00 720x480 60.00 59.94 640x480 75.00 72.81 66.67 60.00 59.94 720x400 70.08 DP-1-0 connected 1920x1080+4480+0 550mm x 340mm panning 1920x1440+4480+0 tracking 6400x1 440+0+0 border 0/0/0/0 1920x1200 59.95 + 1920x1080 59.94* 59.93 50.00 1680x1050 59.95 1600x1200 60.00 1440x900 74.98 59.89 1280x1024 75.02 60.02 1280x720 60.00 59.94 1152x864 75.00 1024x768 75.03 70.07 60.00 800x600 75.00 72.19 60.32 720x576 50.00 720x480 59.94 640x480 75.00 72.81 59.93 59.94 DP-1-1 disconnected 1920x1080 (0x63) 148.500MHz +HSync +VSync h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz 1280x1024 (0x68) 135.000MHz +HSync +VSync h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz 1280x1024 (0x69) 108.000MHz +HSync +VSync h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz 1280x720 (0x6d) 74.250MHz +HSync +VSync h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz v: height 720 start 725 end 730 total 750 clock 60.00Hz 1024x768 (0x70) 78.750MHz +HSync +VSync h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz v: height 768 start 769 end 772 total 800 clock 75.03Hz 1024x768 (0x71) 75.000MHz -HSync -VSync h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz v: height 768 start 771 end 777 total 806 clock 70.07Hz 1024x768 (0x72) 65.000MHz -HSync -VSync h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz v: height 768 start 771 end 777 total 806 clock 60.00Hz 800x600 (0x75) 49.500MHz +HSync +VSync h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz v: height 600 start 601 end 604 total 625 clock 75.00Hz 800x600 (0x74) 50.000MHz +HSync +VSync h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz v: height 600 start 637 end 643 total 666 clock 72.19Hz 800x600 (0x76) 40.000MHz +HSync +VSync h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz v: height 600 start 601 end 605 total 628 clock 60.32Hz 720x576 (0x78) 27.000MHz -HSync -VSync h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz v: height 576 start 581 end 586 total 625 clock 50.00Hz 720x480 (0x7a) 27.000MHz -HSync -VSync h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz v: height 480 start 489 end 495 total 525 clock 59.94Hz 640x480 (0x7b) 31.500MHz -HSync -VSync h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz v: height 480 start 481 end 484 total 500 clock 75.00Hz 640x480 (0x7f) 25.175MHz -HSync -VSync h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz v: height 480 start 490 end 492 total 525 clock 59.94Hz [/FONT]
