Need help with mobile broadband connection
    I've installed Karmic Alpha 5 yesterday andI'm surprised about the good work again, thumbs up !!!
    Now, I'm trying to get a mobile connection with my Samsung NC10, but I'm not really
    sure how to do it. My Provider is t-mobile. As is saw in Ubuntu, t-mobile is already listed
    in the network manager. I have the t-mobile connection data, but I can't get it to work with
    Kubuntu. Can someone explain how it works,please ? Thanks.
    Re: Need help with mobile broadband connection
    I am not sure I know what you mean here.
    Are you trying to connect with a mobile modem or with the wifi card?
    This may be of help:
    http://www.netbooknews.it/en/ubuntu-...-samsung-nc10/
    I don't nave a netbook but I iinstalled the gnome network manager on my laptop (acer travel mate4021) and junked the kde one as it has too many quirks at the moment.
    The gnome nm lets me use both mobile broadband and wifi.
    Hope this helps
    4 GB Ram
    Kubuntu 18.10
      Sorry. I want to connect with my mobile modem, the wificard is working well,
      as I'm writing this here
      Under Ubuntu Jaunty the mobile connection works out of the box, just choose
      your provider and enter your Pin. But under Kubuntu, you have to enter your
      provider settings manually and that's the thing. I'm trying to get the right
      setting for t-mobile ... What package is the gnome network manager exactly ?
      gnome-network-admin ? Maybe I'm trying this out. Thx.
        the package you are looking for is network-manager-gnome and maybe mobile-broadband-provider-info.
        If knetworkmanager gets in the way you can $kill knetworkmanager and start $nm-applet.
        knetworkmanager is working fine for me now, except for vpn support.
        BTW, i googled my isp settings. :P
        Distributor ID: Ubuntu
        Description: Ubuntu Trusty Tahr (development branch)
        Release: 14.04
        Codename: trusty
          Ok, after strugglin around with my mobile connection under Kubuntu Karmic, I'll give it another try.
          I've got my ISP settings, they were working correctly in Ubuntu with Gnome and XP too.
          Number to dial : *99#
          APN : internet.t-d1.de
          Password : equal
          DNS : 193.254.160.1, 193.254.160.130
          Pin : ****
          But it still refuses to work,hmm ... As I see, there is no option in Knetworkmanager for the DNS
          addresses, maybe that's the point ?
            hi,
            if you're remaining problem is domain name resolving you could do this after establishing the connection.
            echo "nameserver 193.254.160.1" > /etc/resolv.conf
            nm-applet from gnome network-manager front-end allows you to specify your dns entries.
            Best Wishes
            Release: 14.04
            Codename: trusty
              This is by no means a solution, but just what I had to do.
              I had mint linux kde (with kde4.2.3) installed on my travelmate and then gave karmic a different partition and username.
              Knetworkmanager never worked with my option icon 225 mobile broadband stick from karmic but did from mint, which uses the gnome networkmanager.
              So copied the following from the mint user to my karmic user:
              .kde/share/apps/networkmanagement/connections
              .kde/share/config/networkmanagmentrc
              and knetworkmanager works fine with mobile broadband.
              I had tried wvdial from here:
              http://kubuntuforums.net/forums/inde...opic=3104766.0
              It works but is cumbersome.
              I really hope they get this fixed soon, but somehow doubt it.
              4 GB Ram
              Kubuntu 18.10
                After RC release I decided to delete my mint partition.
                Broadband mobile stopped working.
                solution?
                Install network-manager-gnome which will also install a providers list.
                After a reboot broadband mobile is working.
                I don't see why I need nm-gnome for this but at least it works.
                4 GB Ram
                Kubuntu 18.10
                  Hi Folks,
                  first of all, I wish all users here a happy new year and want to tell
                  you that I have good news :
                  After thinking about giving up Kubuntu and return to Ubuntu Jaunty
                  (Jaunty is the only distro where my mobile broadband works out of the box)
                  I decided to move to Google again, because I like KDE more than Gnome.
                  After a lot googlin' this problem I found this Kubuntu & Ubuntu Wiki :
                  https://wiki.kubuntu.org/NetworkMana...are/3G/Probing
                  https://wiki.ubuntu.com/NetworkManag...are/3G/Probing
                  (Maybe the same sites )
                  I found out the right bus type and identifiers for my internal samsung
                  NC 10 net book modem, loaded the driver with
                  sudo modprobe usbserial vendor=0x04e8 product=0x6773
                  probed my modem with the probe.txt script described in Kubuntu wiki link above.
                  chat -s -f ~/Desktop/probe.txt >/dev/ttyACM0 </dev/ttyACM0
                  and at last i do a
                  sudo dmesg|grep tty
                  I don't know where i found that but it puts the usb device in the right order,
                  I think.
                  After hacking these three wonderful commands in the terminal, the mobile
                  broadband connection in knetworkmanager works like charm.
                  I also had to put a startup script to overwrite resolv.conf
                  with my needed provider name servers, changed rc.local to load the driver
                  and probe the modem at startup, so I can use it out of the box
                  The only thing I don't really get is that I have to probe the modem
                  with the probe.txt script mentioned above after loading the driver,
                  if i do not, the connection refuses to work ... Maybe someone
                  can explain me why, I thought it's just a test ?
                  I'm really happy with Kubuntu and this proves me that with Linux
                  you can do it all ...
                  I wish a happy new year's day, cheers
