This problem has been around numerous kernel updates, and I know that it wasn't originally like this... But I don't remember when this happened (so I can't tell you what I've installed since then, etc.), or how 'bad' it really is.
Basically, I cannot shutdown the computer. It stops at a time when I can still switch between virtual terminals (ctrl+alt+F1, ctrl+alt+F2, etc.), but I can't do anything with them.
Pressing Ctrl+Alt+Del will restart the computer very promptly.
If I 'restart' my computer, it restarts fine.
What's wrong with it? Is it safe to use 'restart', then shut it down by holding the power button down after it starts to start up again?
