Is Grub going to have problems with booting after I move kubuntu partition?
    I shrank Vista partition from 200Gb to 30Gb. Kubuntu system&swap partitions are now on the far end of the disc, so I am planning to move them with Gparted to just after Vista one, which is on the beginning of HDD. Should i expect problems with booting after doing this? Is Grub going to have problems with finding Kubuntu?
    I want to move them, because the HDD is much faster on the beginning.
    I am also wandering if i should actually bother to download and burn Gparted Live disc, if i could move partitions with EASEUS Partition Master from within Vista. But as they are ext4, I thought they would be better handled by Gparted. Does it actually matter?
    Re: Is Grub going to have problems with booting after I move kubuntu partition?
    Grub2 is linked to a specific partition. So if you move it or change th UUID you need to re-install grub for that partition.
    There's a 1001 links on how to do this. Here's one.
    Boot Info Script
      Just to chime in with my 2.5 cts.
      I concur with the above.
      Beyond that getting gparted live
      http://gparted.sourceforge.net/download.php
      or sysrescue live:
      http://www.sysresccd.org/Main_Page
      is never a bad idea.
      I don't trust windows partitioners at all.
      Bytw think about if getting a few ms extra speed is worth the trouble of reinstalling grub from a live cd.
      Nothing against learning how to reinstall grub, but only when it is necessary
      either way good luck and enjoy
      4 GB Ram
      Kubuntu 18.10
