Boot problem: Karmic won't start, dropping into initramfs
    I'm running Karmic on an AMD 64 on Efficient PC (Re-badged Asus Anubis), with Nvidia Corporation MCP51 High Definition Audio card.
    In recent days my system has been freezing, although this has generally been solved with a reboot.
    Now, however, GRUB is failing to start Karmic, and is dropping me into initramfs.
    I have tried a systemrescue cd (see here http://www.sysresccd.org/Main_Page), which when I switch on slows down at
    ATA1 port is slow to respond
    forcing hard reset
    comreset failed errno=-16
    srs failed errno=-19
    limiting SATA speed to 1.5gbps
    Once I've got the system rescue cd running, I can't mount the either of my partitions /sda1 (ext3) or /sda2 (swap) to run fsck
    booting in recovery mode gives me
    mount: mounting /sys on /root/sys failed: no such file or directory
    mount: mounting /dev on /root/dev failed: no such file or directory
    Done
    mount: mounting /proc on /root/proc failed: no such file or directory
    Target filesystem doesn't have /sbin/init
    No init found. Try passing init= bootarg
    Running dmesg | tail shows
    [2.540798] EXT3-fs error (device sda1): ext3_check_descriptors: Block bitmap for group 384 not in group (block 4023357247)!
    [2.540937] EXT3-fs: group descriptors corrupted!
    On the basis of this I think that I either have a corrupted filesystem, or more seriously, I have a hard disk problem.
    The first thing I want to do is to try to run fsck on sda1 to try to repair any filesystem damage - how can I do this. I've got both a systemrescue dc and a Knoppix disk.
    Suggestions welcome!
    Re: Boot problem: Karmic won't start, dropping into initramfs
    Run the file system check first. This is a hassle of a problem, usually means your initrd isn't available or some such.
    Do what he says to check and repair:
    http://members.iinet.net.au/%7Eherma...xt3_filesystem
      Might have luck using GParted Live CD check and repair it, too.
      Right-click on the partition > Check.
        The first suggestion worked
        Using Knoppix, I opened a terminal and ran
        sudo e2fsck -C0 -p -f -v /dev/sda1
        and the filesystem is now recovered.
        many thanks!
          What a relief!
          I was reviewing my notes about fixing initrd, wondering if we could chroot into your system and do some surgery ...
          Glad you got it -- very nice work on your end!
