Hi. I'm trying to install Kubuntu 9.04 using Wubi. Installation finishes successfully, but when I reboot and select Kubuntu it shows blue progress bar and then my HDTV (I use it as a display) says "Signal is not supported. Check your PC settings." My TV max resolution is 1360x768 60Hz. I think the problem is that Kubuntu sets higher resolution. I don't have another monitor. Tell me what to do, please!
