I have a dualboot system with Kubuntu 9.04 and WinVista. On Kubuntu boot (default) I have this inter,ittent problem of limited display resolution (800X600) fixed (with fixed refresh rate). Sometimes startup works fine with maximum resolution but intermittently I cant get past the above mentioned resolution even on repeated reboot.
I have a Geforce 5200 FX graphics card. Is that the problem? Im sure its not, otherwise how do I get the correct resolution?
How do I correct this intermittent glitch?
