I would like to install Kubuntu 9.04 to my system using the Alternate Install CD, since it is capable of recognizing and installing to a so-called "fake" RAID, of the type offered by the Intel ICH9R chipset (as on my motherboard, an Asus P5E3 WS Pro). However, when I get to the part where Kubuntu want to set up partitions on which to install itself, things go all wrong.
Most importantly, the installer doesn't see ANY of the existing partitions. In reality, the RAID-1 contains two 1 TB SATA 2 HDD's, partitioned as follows, going from start to end of disk:
20 GB NTFS boot partition (Windows XP SP3 boot volume)
800 GB NTFS partition (used to store data)
*10 GB Ext-3 / partition for a previous Kubuntu 8.10 64-bit install
*4 GB swap partition that goes with the Kubuntu 8.10 install
*20 GB Ext-3 /home partition, again part of the Kubuntu 8.10 install
100 GB Ext-3 partition (can't remember the mount point, just used for general data storage)
The three marked with a * are logical drives on the same extended partition (if I have my terminology correct), for the maximum total of 4 primary & extended partitions.
I've verified that other Linux environments see it this way. For example, when I use Clonezilla to image my Windows XP boot volume, it sees two SATA drives, each with the 6 partitions listed above. Kubuntu 8.10 has no problem with any of it, except that it sees two hard drives, since I didn't install it on to the RAID 1. I didn't know how at the time.
But the Kubuntu 9.04 alternate CD installer sees only one 1.0 TB RAID, which it claims is unformatted.
That leads to the other problem. The only options I'm presented are to automatically partition, using the entire 1.0 TB "disk" (really a RAID-1 of two 1 TB disks, remember), or to manually partition, in which case it will rewrite the partition table, destroying any existing partitions. This is true even if I elect only to make one or two ext3 partitions, even if I put them at the end of the disk, and they are small enough that they should not overlap with the existing NTFS partitions.
Isn't there some way I can install Kubuntu 9.04 to the RAID, without wiping out the NTFS partitions? I don't care what happens to the ext3 volumes, as I've already backed up everything I needed from the Kubuntu 8.10 install.
Do I need to delete the ext3 partitions for things to work correctly?
