What should I do to keep the printer listed?
I have a standalone PC with a USB HP LaserJet 1022. As a power saving I turn off the monitor ( USB hub the printer is connected through the monitors' USB jack ) via a power strip on the desktop. When I sit at the computer to work I turn on the powerstrip and move the mouse. The computer comes on from sleep but then I get a message in the lower right that says "configuring new printer..." and I look and sure enough, the printer I added yesterday is gone!
Also, I had to add the printer via "network" as it would not see it otherwise. I am using the stock 9.04 CD install and this PC is never on a network. I am using OpenOffice spreadsheet only.
