Sound missing from some applications - still struggling with audio
    Re: Sound missing from some applications
    Yes, sorry for not mentioning that.
    Regards,
    Oceanwatcher
    Blog: http://www.wisnaes.com/
    Pictures: http://www.oceanwatcher.com/
    Software tips (in Norwegian): http://www.datahverdag.com/
      Don't know what it could be? It helped some other people and it helped me. The thing that is buging me is that you cannot test sound. That should work in any case.
        Yeah. I have installed VLC as well and included a Pulseaudio plugin. But no sound when playing an MP3 there. Not using Pulseaudio and not using ALSA.
        Regards,
        Oceanwatcher
          I am now getting closer to the audio hell I have been in before...
          Just had a full shutdown (instead of a reboot) and start again. After finishing booting, I went to settings to test audio. All I got was a bzzz in the speakers as if the speakers were blown (which they are not). There was only a couple of positive things - I got the same bzzz from the Pulsaudio as from ALSA, I assume it is ALSA. They are only is only labelled HDA Intel (STAC92xx Analog) and HDA Intel (STAC92xx Digital).
          One more positive thing - I now have the same bzzz when there is a new twitter coming in on Twhirl.
          But altogether, not very uplifting. It has gone from bad to worse.
          Regards,
          Oceanwatcher
            There's a sound troubleshooting link in my signature FAQs, I think it is #6.
              I will take a look at that. Thank you.
              Of course, this morning when I booted my laptop, the sound was back. When testing, the analog part was ok, and Pulseaudio was dead silent again. As before, when I press the test button in the config, it seems Pulseaudio is playing it, but no sound comes out.
              I am just wondering... isn't Pulseaudio I kind of higher layer that uses ALSA as an underlaying technology?So... what if Pulseaudio is pointing to the digital out?
              Regards,
              Oceanwatcher
                Have started to look through this page
                http://ubuntuforums.org/showthread.php?t=205449
                Found the section about groups and checked what was in there on my laptop
                audio:29ulse
                So I added my user to this line.
                Now I have sound playing on ALSA, and a crackling bzzz in when I try to test Pulseaudio.
                Regards,
                Oceanwatcher
                  Seems I am getting a little bit closer to figure out why things are not working with Skype, at least.
                  I thought it might not harm to add OSS for ALSA and then try to set Skype to use it.
                  When I ran alsa-oss skype I first had to crash out of Skype because it tried to open a Skype again. So if you try this, make sure the program you want to configure is not already running.
                  On the second try, it worked better, but I got this message in the terminal:
                  ALSA lib pcm_bluetooth.c:1569audioservice_expect) BT_GET_CAPABILITIES failed : Input/output error(5)
                  I know that bluetooth on this laptop has some high quality audio possibilities. Could it be that this is interferring with the rest of the audio setup and that somewhere some audio setting is pointing to bluetooth instead of the Intel HD audio?
                  Regards,
                  Oceanwatcher
                    I'd try shutting down the Bluetooth magic until the basic audio functions are working correctly. You might need to use BIOS to shut Bluetooth down.
                      Ok. I will try that.
                      Regards,
                      Oceanwatcher
                        No change.
                        In the meantime I found this command that can be typed in a terminal window to "communicate" with PA
                        pacmd
                        I tried listing the cards in my laptop and got this:
                        [code]
                        >>> list -cards
                        Memory blocks currently allocated: 10, size: 73.0 KiB.
                        Memory blocks allocated during the whole lifetime: 10123, size: 9.8 MiB.
                        Memory blocks imported from other processes: 9, size: 9.0 KiB.
                        Memory blocks exported to other processes: 0, size: 0 B.
                        Total sample cache size: 0 B.
                        Default sample spec: s16le 2ch 44100Hz
                        Default sink name: alsa_output.pci_8086_27d8_sound_card_0_alsa_playba ck_0
                        Default source name: alsa_input.usb_device_46d_8c6_48996D91_if2_sound_c ard_0_alsa_capture_0
                        Memory blocks of type POOL: 1 allocated/4541 accumulated.
                        Memory blocks of type POOL_EXTERNAL: 0 allocated/0 accumulated.
                        Memory blocks of type APPENDED: 0 allocated/0 accumulated.
                        Memory blocks of type USER: 0 allocated/0 accumulated.
                        Memory blocks of type FIXED: 0 allocated/4171 accumulated.
                        Memory blocks of type IMPORTED: 9 allocated/1411 accumulated.
                        15 module(s) loaded.
                        index: 0
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 1
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 2
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 3
                        argument: <device_id=1 source_name=alsa_input.usb_device_46d_8c6_48996D91 _if2_sound_card_0_alsa_capture_0 tsched=0>
                        used: -1
                        auto unload: no
                        index: 4
                        argument: <device_id=0 sink_name=alsa_output.pci_8086_27d8_sound_card_0_a lsa_playback_0 tsched=0>
                        used: -1
                        auto unload: no
                        index: 5
                        argument: <device_id=0 source_name=alsa_input.pci_8086_27d8_sound_card_0_ alsa_capture_0 tsched=0>
                        used: -1
                        auto unload: no
                        index: 6
                        argument: <tsched=0>
                        used: -1
                        auto unload: no
                        index: 7
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 8
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 9
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 10
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 11
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 12
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 13
                        argument: <>
                        used: -1
                        auto unload: no
                        index: 14
                        argument: <>
                        used: -1
                        auto unload: no
                        1 sink(s) available.
                        * index: 0
                        driver: <modules/module-alsa-sink.c>
                        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
                        state: SUSPENDED
                        volume: 0: 56% 1: 56%
                        muted: no
                        current latency: 0.00 ms
                        configured latency: 0.00 ms; range is 81.27 .. 81.27 ms
                        max request: 14 KiB
                        max rewind: 0 KiB
                        monitor source: 1
                        channel map: front-left,front-right
                        used by: 1
                        linked by: 1
                        module: 4
                        properties:
                        device.api = "alsa"
                        device.class = "sound"
                        alsa.class = "generic"
                        alsa.subclass = "generic-mix"
                        alsa.name = "STAC92xx Analog"
                        alsa.id = "STAC92xx Analog"
                        alsa.subdevice = "0"
                        alsa.subdevice_name = "subdevice #0"
                        alsa.device = "0"
                        alsa.card = "0"
                        alsa.card_name = "HDA Intel"
                        alsa.long_card_name = "HDA Intel at 0xefffc000 irq 21"
                        device.description = "HDA Intel - STAC92xx Analog"
                        device.string = "front:0"
                        device.buffering.buffer_size = "14336"
                        device.buffering.fragment_size = "1792"
                        device.access_mode = "mmap"
                        3 source(s) available.
                        * index: 0
                        name: <alsa_input.usb_device_46d_8c6_48996D91_if2_sound_ card_0_alsa_capture_0>
                        driver: <modules/module-alsa-source.c>
                        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL LATENCY
                        state: SUSPENDED
                        volume: 0: 0%
                        muted: no
                        configured latency: 0.00 ms; range is 80.00 .. 80.00 ms
                        max rewind: 0 KiB
                        sample spec: s16le 1ch 16000Hz
                        channel map: mono
                        used by: 0
                        linked by: 0
                        module: 3
                        properties:
                        device.api = "alsa"
                        alsa.name = "USB Audio"
                        alsa.id = "USB Audio"
                        alsa.device = "0"
                        alsa.card = "1"
                        alsa.card_name = "USB Device 0x46d:0x8c6"
                        alsa.long_card_name = "USB Device 0x46d:0x8c6 at usb-0000:00:1d.7-5, high speed"
                        device.description = "USB Device 0x46d:0x8c6 - USB Audio"
                        device.string = "hw:1"
                        device.buffering.buffer_size = "2560"
                        device.buffering.fragment_size = "320"
                        index: 1
                        name: <alsa_output.pci_8086_27d8_sound_card_0_alsa_playb ack_0.monitor>
                        flags: DECIBEL_VOLUME LATENCY
                        state: SUSPENDED
                        volume: 0: 100% 1: 100%
                        muted: no
                        max rewind: 0 KiB
                        used by: 0
                        linked by: 0
                        monitor_of: 0
                        module: 4
                        properties:
                        device.description = "Monitor of HDA Intel - STAC92xx Analog"
                        device.class = "monitor"
                        index: 2
                        state: SUSPENDED
                        volume: 0: 89% 1: 89%
                        muted: yes
                        max rewind: 0 KiB
                        used by: 0 &n
                        Regards,
                        Oceanwatcher
                          Just checked. I also miss sound from flash when playing something in Firefox.
                          There HAS to be a solution. I read a lot around the internet now about different sound systems, and it it very obvious that the diversion here is a major problem.
                          The fact that so many different systems exist is actually working against Linux when it comes to hardware manufacturers. In this case, the hardware manufacturers can not be blamed for not making drivers available. As long as the community can not agree on what system to get drivers from, hardware manufacturers will be reluctant to jump on. And all the application programmers out there are confused about what to go for.
                          Maybe time for a talk between all the biggest distros on a top level and make a decision on what to go for and leave everything else for the specialist distros? This would at least ensure that something worked... There is a lot that can be said about freedom and that should not be limited. On the other hand - it is good to have something that actually work across the board to fall back on when a smaller system do not work :-)
                          Regards,
                          Oceanwatcher
                            thanks for the pulseaudio solution!
                            now i am listening radio on vlc without the computer getting frozen.
                            an improvement since this morning when i didn't have sound on vlc and the system was most time frozen.
                            thanks again
                            yhotg<br /><br />--------------<br />dibl&#39;s Top 20 Kubuntu FAQs
                              Well, I still have not figured things out on my laptop.
                              ALSA is working, but when I click the test for pulseaudio in the Multimedia settings, I just get the digital bzz in the speakers.
                              Hovering over the different options in the Multimedia settings shows what devices they will use. Pulesaudio do not show any devices. I just say it is the Xine audio output plugin using pulseaudio server.
                              So can it still be that I actually do not have pulseaudio properly installed?
                              Should I just install everything I can find in KpackageKit that has anything to do with pulseaudio except for all the debugging packages, maybe? Can it break anything?
                              Regards,
                              Oceanwatcher
                                Re: Sound missing from some applications - still struggling with audio
                                What does pulseaudio provide that you don't have now? I don't have pulseaudio installed, as far as I can tell, and I don't think I'm missing anything. I use xine as my backend.
