On the PC where I have Linux Mint installed I have an audio problem that almost made me tear my hair out (or the rest of it). Seems like I have the same problem on my laptop.
Different distro (maybe not THAT different...), different hardware. Same problem.
Here is what is happening:
I am naive enough to believe that it should be possible to have audio from all applications at the same time. So I want the OS to give warning signals etc., I want Amarok to play, and I want Skype and Kopete to do their pling when they feel like.
Right now, I have audio from Amarok and nothing else. Skype does not work, Kopete do not utter even a little beep.
Where do I start looking? Have anyone else here sound from Both Amarok and Kopete at the same time?
My laptop is a Dell XPS M1210 just in case somebody is familiar with it. I am playing music with Amarok right now, so there is nothing wrong with the hardware.
Addition: I think ALSA is working ok most of the time. System sounds seem to be working. Kopete give warning sounds, but it seems pulseaudio is still not configured right. At least there is some kind of bzz in the speakers when I try to test pulseaudio. But nothing that can be recognized as SOUND.
Try going to System Settings and play around with the default audio devices, usually something branded for example "Nvidia" will work better than something like "Pulse Audio". You can also try clicking the "Defaults" button and see if that fixes your problem, that seems to work for me. The sound will most likely go away when watching Flash videos but you will notice once you stop watching them Amarok, Kopete, etc. will get their sound back. Good luck.
