I'm rather new to kubuntu (running 8.10); previously I was running windows vista but I was using thunderbird and lightning for email and calendar.
The version of thunderbird supported by the repositories appears to be an older one; unfortunately the calendar data is not backwards compatible and I had to install thunderbird manually. That actually works fine, except that it looks like an old windows 98 application... nothing of the new and fancy look... (firefox does not have this problem)
I get the following error when I start thunderbird from the konsole:
Does anyone know what this is? I tried (re-)installing some gtk and qt4 libs but that didn't help at all (mostly they were already present)
So all the functionality of thunderbird (2.0.0.19) is there but it simply looks "old"... (it looked much better in windows...)
/$ /opt/thunderbird/thunderbird
(thunderbird-bin:31407): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/engines/libqt4engine.so: wrong ELF class: ELFCLASS64
