X Problem when Upgrading to 8.10!!
    I have been looking forward to using 8.10 for months now, but my upgrade has not gone well. First, the downloads hung, and when I tried to upgrade again nothing happened. After a reboot, I could not get an xserver. However, I used command line to do a full upgrade, and things seemed to work well.
    But now my xserver won't start. I tried doing sudo startx and I got Rgbpath not being a valid keyword in the the Files section. So I commented that out. But then I tried again it said that it could not load the modules freetype, v41, or nvidia, because the modules did not exist.
    I would really appreciate any help on this. I am very stuck because I have no way of starting X and now my laptop is pretty much useless!!
    I have attached my xorg.conf file, as well as Xorg.0.log.1 (when it complains about Rgbpath) and Xorg.0.log2 (when it complains about the modules not being present). I had to add .txt so it would let me attach them.
    Re: X Problem when Upgrading to 8.10!!
    Have you tried rebooting into the recovery mode?
    Firstly choose the command line option and do
    sudo dpkg --configure -a
    That should fix any dodgy software installations
    Then Try startx
    If that doesn't work then take the recovery mode option of "fix X"
    Any joy?
    ian
      I tried repairing the packages and fixing x. It wrote a new xorg.conf file using the vesa drivers, but it comes up with a similar error message:
      Failed to load module "vesa" (module does not exist, 0)
        UDATE:
        So I think that somehow my nvidia drivers were unloaded completely during the upgrade. I loaded the nvidia-glx-177 series drivers, and that seems to have helped a bit.
        I can now get a logini screen (resolution is all messed up but it is a start). However, kwin crashes at login.
        Any new thoughts on what to do next?
          Originally posted by rlynch
          UDATE:
          You are most likely correct there. Seems to have happened to several folks, myself included.
          (In my case, my system came back after installing the proprietary driver again. )
          I guess all we can really do is wait for an update/fix.
          (I'm still getting minor graphics glitching here and there.)
            Were you still able to log in? Did kdm or kwin give you any problems?
              I was able to log in via recovery. (Just skip the repair tools... they don't fix a darn thing for this problem... and continue to boot - first option). Worked for me... didn't for some others here.
                GETTING SOMEWHERE!
                I was able to reinstall kwin and kdm and now I am logged in to KDE4! Joy.
                BUT there are still some resolution problems, amarok is complaining about something, and something else will still come up, I am sure.
                But if you have problems with the xserver, I recommend trying the above approach.
                Try modprobe nvidia...when things weren't even installed it said so.
