Hello, I am not new to Linux, this is my first post to K Forums, though, I have used Launchpad in the past to report developer problems but got directed to this site this time so here goes
OK 2 separate PC's ..neither will install.
Disk ISO integrity verified
PC 1 ASUS P4R800V PC 3200 3.2 ghz P4 2 gigs ram and is a cold swap hard drive unit I run Knoppix, SuSe Linux 11.0 and keep a spare drive for Kubuntu or Ubuntu ...my card is ATI radeon 9000 series, and built into the MOBO...my screen is CRT on this box and a 17 inch Phillips
I got a very slow install to hard disk , the page opened to 1600 dpi and I tried to set screen rez to the 1280 x and the hz to 85 for a CRT , it did not ask for my password either and the whole install froze and sound ( AC 97 ) which was working stopped. and K menu looked like Charles Manson on Crack ..all wavy lines and hallucinogenic strobescent pattern
I scrubbed disk, ..de magnetized the disk with ( Spinrite) and reinstalled and got the same problems PLUS now K Menu wont work ..I force restarted scrubbed disk reformatted and stopped ..end of story with PC 1
PC 2 680 lti Systemax 4 gigs ram DDR 2 PC 5300 , Graphics card NVidea 7700 series and realtec sound screen 20 inch LCD wide screen ..ran as Live CD only in a Windows XP Pro system. Live CD user install the slowest ever ...and same probs with the screen rez probs BUT all worked otherwise and the hz for screen right at 60 , sound works BUT it was the slowest ever Live CD user session I have ever had
I have used SuSe since the 7 series , Ubuntu since the 5.10 series , and made numerous time and effort contributions and posts in launchpad, but now I am sent here. So I guess something has changed ??
Education..well, I was at MIT when Stallman was there, I was upstairs in Dept of Electrical Engineering..So I have been a fortran freak since the days of yore and yesteryear , retired now and beta test about 20 programs a year
Loved the look of the KDE 4.1 ..I ran the KDE 4.0 remix last year and had no probs until one update then it said my screen was out of frequency rate and went into kernel panic
Hope these bugs are fixed before K and U 8.10 launch in 2 weeks
Sidux installs in 5 minutes flat, if you're all about installation speed.
