ok so first the multimedia keys...
i have them working (even though when i press mute the led doesnt shine its working), but in a gross way, when i press vol.up it only calls the service but doest really pull the sound up or down...
so i need to know where exactly do i config these keys specifically.
also, i HOPE that ubuntu devs dont expect to release this 'multimedia compatibility' as is.
anyways, over to the battery.
its a very strange issue, while inside the liveCD, it worked great.
as in, it was -not charging(what i wanted), and when i pressed my 'charge' button on my laptop's keyboard it started charging, the appropriate light was on quite remarkable really.
but then when i go to the installed system... the button is ignored AND my battery is charging...
if i had to choose id just rather have it not charge, like i said. or ideally -only charge till 50%~.
...crazy stuf...
...crazy stuf...
