Problem with game > Help ID the problem?
    I just found my old Uplink game CD and tried it on my laptop. I followed the readme.txt to install (Extract uplink.zip to directory > Change permissions on /uplink/uplink to be executable > Run)
    Here's what the terminal comes up with:
    digitalhead@d101:~$ games/uplink/uplink
    games/uplink/uplink: symbol lookup error: games/uplink/uplink: undefined symbol: __glutRoot
    digitalhead@d101:~$ cd games/uplink
    digitalhead@d101:~/games/uplink$ ./uplink
    ./uplink: symbol lookup error: ./uplink: undefined symbol: __glutRoot
    What is "undefined symbol: __glutRoot" and is there a way for me to fix it or is the game just too old to be compatible with Hardy?
    Keyboard not detected. Press F1 to continue...
    Re: Problem with game > Help ID the problem?
    Check out Re: Getting Uplink running on Ubuntuforums.
      Interesting. It attempts to startup after applying the patch, but when it opens, it immediately closes. The terminal comes up with:
      digitalhead@d101:~$ uplink -graphics_fullscreen +game_debugstart
      /usr/lib/uplink
      =    U P L I N K    =
      =    Version 1.54    =
      =   - R E L E A S E -   =
      Version 1.54 (RELEASE)
      Compiled on Nov 16 2006 at 20:46:23
      (code-C)(code-M)(code-T)
      Aborted
      It did this from ~/games/uplink, and also when I copied it to /usr/lib/uplink and a symlink for /usr/bin/uplink to the game executable.
      I'm not overly concerned if this game doesn't work to be honest, but out of curiosity, is there a similar (preferably open source and free) game available for me to kill time with? Uplink is kind of dated anyway.
        On the Ubuntuforums post, did you read through it all? I saw posts about certain packages that needed to be installed? You can test to see if those are installed from a console with:
        sudo apt-get install --simulate package_name
