Hey everyone, wanting to know if I have my connection speed fully taken advantage of. I have a cable connection, going through a Linksys wireless g/n router, and then my laptop is connected to wireless with 54 MB/s potential. I want to see if there is any way to change/check/optimize connection speed for downloads. Thanks to anyone who has suggestions or solution
Making sure speed is at max
Re: Making sure speed is at max
I've heard of people tweaking mtu and things like that, but as long as your not running in mixed mode on the router, ie, N and G and have n and g devices then the default settings should have you there at the top.
so if the laptop runs n set the router to run only n. also you check your speed with
and it should give you the speeds and connection strength for the deviceCode:iwlist [interface] scan
- kubuntu 11.10 | linux User #231826 | kubuntu user #23718<br />- x58/ich10r | i7-950 | 3@2GB 1600 3x channel | geforce gt240 1GB [19" 16:10, 19" 4:3] | 120GB ssd / 500GB / 1TB / dvd+-rw [sata ahci] | 600W wrapped in aluminum
