Hi, I'm running Hardy, and would like to have another partition to run another distro of Linux, and am wondering if it is possible to have the two distros use the same home partition, and if I can have the same swap partition for them both. Or do I need to have two swap partitions? Is there anything I would need to know to do this, or can I just make partitions with GParted and install the other distro on one of them?
The reason I want to do this is because I want to have a partition where I can test other distros without getting rid of my tried and true rock solid beloved Hardy. I want to access the same files so that I don't have to keep remembering to copy back and forth to get the latest version, like my KMyMoney file.
Thanks!
Thanks!
) and all the tools you might need - gparted, all disk format tools, and the like. Then leave it alone. Don't do much updating and don't install stuff on it you don't need. Use it to boot to if you mess up your other install and you need to recover. Finally, put the distros you're playing around with at the end of the disk. That way you can delete, resize and reformat them to your hearts content without messing up your main install and data files.
