Hi, i used the live CD and installed Kubuntu inside windows in an 8GB file, not partion. I have to remove it again to regain the space so i can backup windows, then I will format the hdd and make a clean install.
The probleme is just that the Uninstall doesn't work. I tried from windows add/remove and for a moment it seens it start but then nothing. I went to the ubuntu folder and ran the uninstall there, but samething happen - or should i say didn't happen.
I tried reinstalling Kubuntu from the liveCd but it only starts extracting then dissapears and nothing happens.
How can I remove it?
With kind regards
JBJ
With kind regards
JBJ
I will try that later today
