I just installed Hardy. My system didn't shutdown properly, so I applied the fix found on jerrylamos's post here: http://ubuntuforums.org/archive/index.php/t-628109.html
(I would have posted this there, but it appears to be closed.)
That fixed the shutdown problem, but now my battery monitor is gone. I tried installing a couple of battery monitor programs; all of these show that my laptop is plugged in with no battery when, in fact, I am running on battery power.
Can anyone suggest a fix?
Thanks.
Thanks.
