have kubuntu 8.04 i have only one user for the pc and want to make it auto login when i open pc. i went to system setting - Advanced - log in manager i cannt edit anything here i cannt get adminstration. how to edit anything here? how to get adminstration for system seting? in kubuntu 7.10 there was a button for admin and then enter the root pass but here i cannt find this button how i do that??
ho to get adminstratioin for system setting
Re: ho to get adminstratioin for system setting
Are you running HH remix with KDE 4? I've noticed that the functions in KDE 4 are seriously lacking when it comes to Administrator functions. The button in question does not exist!Using Kubuntu Linux since March 23, 2007
Originally posted by AHAROON111someone told me to try kdesudo systemsettings i'll try this. but do you mean HH mixed kde4 which i use is still not stable?? does it crashes with normal or regular user? do u think now i have to stay with kubuntu 7.10 is better?Registered Linux User: #281828 | Kubuntu User: #22280
Kubuntu 18.04 LTS
Dell Precision Workstation T5500 (Xeon @ 2.13GHz x 2 / 12 GB RAM)
KDE4.0.x is not finished, and has the occasional rough edge, such as the lack of a fully functioning "settings" module, as you found. But, I've been running it for 10 weeks or more, and it has never outright crashed. Unless there is some particular hardware or graphics compatibility problem with your setup, I don't know why you couldn't use it. If you like KDE 3.5.9 better, then that's fine too.
