Running AMD 64 on Efficient PC, with nvidia Corporation MCP51 High Definition Audio card
I'm having a problem with sound on my Hardy installation, after an abortive installation of some updates last night. As the installation slowed badly I switched off like an idiot. Hence the problem...
fsck sorted the file system, and the recovery of the screen resolution is detailed here...
http://kubuntuforums.net/forums/inde...opic=3096180.0
However a number of attempts haven't yielded a solution to the problem of no sound.
Kmix shows the red circle with the white X, and the message 'Mixer cannot be found'
I've checked system settings, and that hasn't sorted anything. I've also used a few guides, particularly this one at
http://ubuntuforums.org/showthread.php?t=205449
Unfortunately, much of this is negated as I can't find if there's an ALSA driver for my soundcard at
http://www.alsa-project.org/alsa-doc/
I've opened a terminal and run a few scripts. The sequence that I've used is
aplay -l
aplay: device_list:205: no soundcards found...
then
lspci -v
which shows the following
00:10.1 Audio device: nVidia Corporation MCP51 High Definition Audio (rev a2)
Subsystem: ASUSTeK Computer Inc. Unknown device 81cb
Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 11
Memory at fe028000 (32-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Then I tried
'sudo modprobe snd-'
which gets the response
FATAL: Module snd_ not found.
Then
'lsmod | grep snd:'
which didn't get any response
I followed this with
'sudo apt-get --purge remove linux-sound-base alsa-base alsa-utils'
this runs, and generates the following error message
(Reading database ... dpkg: error processing /var/cache/apt/archives/linux-image
-2.6.24-19-generic_2.6.24-19.36_i386.deb (--unpack):
files list file for package `linux-image-2.6.24-19-generic' is missing final newline
/var/cache/apt/archives/linux-image-2.6.24-19-generic_2.6.24-19.36_i386.deb
Processing was halted because there were too many errors.
Then I tried
'sudo apt-get install linux-sound-base alsa-base alsa-utils'
which generates this error message
(Reading database ... dpkg: error processing /var/cache/apt/archives/linux-image -2.6.24-19-generic_2.6.24-19.36_i386.deb (--unpack):
Then I tried
'aplay -l'
again, but still no soundcard showing
Then I tried
'sudo apt-get install build-essential linux-headers-$(uname -r) module-assistant alsa-source'
which generates the same error message
(Reading database ... dpkg: error processing /var/cache/apt/archives/linux-image-2.6.24-19-generic_2.6.24-19.36_i386.deb (--unpack):
Then I tried
'sudo dpkg-reconfigure alsa-source'
and got
Package `alsa-source' is not installed and no info is available.
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
/usr/sbin/dpkg-reconfigure: alsa-source is not installed.
John@ubuntu:~$ sudo dpkg-reconfigure alsa-source
Then I tried
which generates
Finally, I tried
'sudo apt-get install alsa-utils'
This generated
then I tried
sudo /etc/init.d/alsa-utils reset
which generates
* Resetting ALSA... [ OK ]
but the sound still didn't work, after switching off and rebooting
I've also run sudo lspci -v
and got
Capabilities: [44] Power Management version 2
Capabilities: [50] Message Signalled Interrupts: Mask+ 64bit+ Queue=0/0 Enable-
Capabilities: [6c] HyperTransport: MSI Mapping
Does this say anything more, that's useful?
Sorry to burden people with a lots of script, but I'm not sure what's important here.
Would using
be a useful next move?
Or alternatively, based on some reading I've been doing (Running Linux; Dalheimer and Welsh), should I look at reinstalling the kernel?
Any ideas?
aplay -l
then
lspci -v
Then I tried
Then
'lsmod | grep snd:'
Then I tried
Then I tried
'aplay -l'
Then I tried
Then I tried
and got
Then I tried
which generates
Finally, I tried
This generated
then I tried
which generates
and got
Would using
Any ideas?
