Edimax 7728ln pci wireless card problem
    Hello,
    I bought Edimax 7728 pci card for a friends computer. I installed Kubuntu but it couldnt specify the card.
    I downloaded driver from Edimax site. While trying to install there are some errors attached here.
    karel@Karels:~/Desktop/2008_0108_RT2860_Linux_STA_v1.5.0.0$ sudo make
    make -C tools
    make[1]: Entering directory `/home/karel/Desktop/2008_0108_RT2860_Linux_STA_v1.5.0.0/tools'
    gcc -g bin2h.c -o bin2h
    bin2h.c:28:19: error: stdio.h: No such file or directory
    bin2h.c:29:20: error: string.h: No such file or directory
    bin2h.c:30:20: error: stdlib.h: No such file or directory
    bin2h.c: In function ‘main’:
    bin2h.c:34: error: ‘FILE’ undeclared (first use in this function)
    bin2h.c:34: error: (Each undeclared identifier is reported only once
    bin2h.c:34: error: for each function it appears in.)
    bin2h.c:34: error: ‘infile’ undeclared (first use in this function)
    bin2h.c:34: error: ‘outfile’ undeclared (first use in this function)
    bin2h.c:42: warning: incompatible implicit declaration of built-in function ‘memset’
    bin2h.c:45: warning: cast to pointer from integer of different size
    bin2h.c:46: warning: cast to pointer from integer of different size
    bin2h.c:49: warning: incompatible implicit declaration of built-in function ‘printf’
    bin2h.c:54: warning: incompatible implicit declaration of built-in function ‘printf’
    bin2h.c:57: warning: incompatible implicit declaration of built-in function ‘strcat’
    bin2h.c:69: error: expected expression before ‘)’ token
    bin2h.c:71: warning: incompatible implicit declaration of built-in function ‘printf’
    bin2h.c:76: error: expected expression before ‘)’ token
    bin2h.c:78: warning: incompatible implicit declaration of built-in function ‘printf’
    bin2h.c:146: warning: incompatible implicit declaration of built-in function ‘sprintf’
    bin2h.c:155: warning: incompatible implicit declaration of built-in function ‘exit’
    make[1]: *** [all] Error 1
    make[1]: Leaving directory `/home/karel/Desktop/2008_0108_RT2860_Linux_STA_v1.5.0.0/tools'
    make: *** [build_tools] Error 2
    Can anybody help with this problem.
    Thank You Anyway.
