I have an Acer PC with a Belkin USB wireless card that works fine with Kubuntu 7.10 Gutsy Gibbon. The problem is, it is not detected every time I boot the machine. Sometimes I can boot into Windows Vista and then back into Kubuntu and the card works, sometimes it doesn't. On the occasions that it is detected, the LED indicator on the card goes out briefly (during startup). So many times, I just keep rebooting (Ctrl+Alt+Del) if the light doesn't go out by the time the blue progress bar hits a certain point.
Is there a way to force detection of the card every time I boot into Kubuntu?
Steve
Steve
