Here is the scenario...
I have two hard drives in my pc. The one (C
is SATA and contains Windows XP. The other is IDE (E
and is the one that i plan to install Kubuntu. With Partition Magic i created a swap partition and two other partitions one for kubuntu and the other for home. i started the installation and proceeded to manual configuration of the hard drives. i set the mount points correctly and started the installation. After everything was done i restarted the system and removed the CD but the Windows screen appeared!! I have checked the selection for the boot loader. What is wrong then?
PS: both C: and E: are shown in partition magic as ACTIVE? Can this be the problem?
