[SOLVED] not working all of a sudden ( startx problem )
    i shutdown my laptop..
    the next day, i tried booting it. it loads everything and suddenly instead of the kdm showing up, i get the command line
    i logged in and ran startx.. but it gives me an error and returns to the command line
    please help me out
    also how do i capture the output for startx? so that i can put it up here
    Re: not working all of a sudden ( startx problem )
    Was there a kernel update or something, the last time you were using it? It sounds like your video driver isn't working, which is normal if it is a proprietary driver, after a kernel upgrade.
    To configure a VESA display, for the interim, boot in "recovery" mode, which will take you to a root user prompt "#", and do the following:
    dpkg-reconfigure xserver-xorg
    This runs a video configuration script. On the first screen you probably need to answer "NO" to autodetect, and on the second screen choose "vesa" as the display type. Answer the rest of the script questions as best you can -- defaults are normally fine for the keyboard and mouse questions (you don't need to autodetect your keyboard, normally). When the script finishes, it will dump you back to the command line. Since you're still root, you should probably just shut down and restart, with
    shutdown now -r
    and then try again with your normal user login procedure.
      before i do anything that you have told me, thought ill put in this
      if i try to do a normal boot,
      i get the following message after which im given a command line to login .. etc
      starting up ...
      Loading, please wait...
      kinit: name_to_dev_t(/dev/disk/by-uuid/....) = sda(8,8)
      kinit: trying to resume from /dev/disk/by-uuid/....(same as above)
      kinit: No resume image, doing normal boot...
      Ubuntu 7.10 MyLaptop tty1
      MyLaptop login : _
        Yep, that all looks normal. Go ahead with the instruction I gave and see if that gets you going.
          i did what u said in your earlier post
          man it works..
          ur GOD
          all hail dibl
          thanks
            Originally posted by terrordrone
            ur GOD
            Now YOU are the God of YOUR PC!
              haha
              how do i set the status of this thread to solved?
              how long have you been using linux... u seem to know everything
                Thanks for the compliment, but ... I may know 15% of it, after a couple of years.
                Open your original post with "modify", then just add "SOLVED" at the front of your title.
                Thanks!
                  Re: [SOLVED] not working all of a sudden ( startx problem )
                  thought id do that.. but before i clicked on save.. i thought there must be some other way than this..
                  anyways.. thanks again
