Partition problems again - and running out of space soon
    After upgrading and keeping Gutsy up-to-date at all times. I could no longer access it. My partition was full.
    Resolved the problem temporarily by moving as many data files and unused (or rarely used) applications off the partition. Now it is working again.
    Attempted to increase the size of the boot partition with Gutsy on it. Did not work, because:
    The free space is part of an extended partition (lba) and I used up all primary partitions.
    Hard drive layout:
    hda
    hda1 (boot) 7.81 Gig
    extended lba 25.57 Gig
    partitioned:
    hda5 5.94 Gig
    hda6 8.42
    hda7 8.41
    hda8 2.79
    hda3 1.86 primary (Fat32, now ext3) unallocated right now
    hda4 313 Mb linux swap.
    There is an unallocated sector of 2.47 Gig that I want to incorporate into hda1 to make more room for future OS updates.
    Right now I cannot do it, because I have used up all of my primaries and do not know how to make this free unallocated space (next to hda1) part of that partition.
    I have to be very careful because hda1 is my boot partition. It controls 2 hard drives and the partitions and various flavors of Kubuntu on them.
    Can anyone give me a detailed, step by step guide to fixing my partition table, please.
    I cannot afford to wipe out any data. Already attempted to move my most important data to CD but it did not really work either. Off site BU is to involved for just a minor adjustment of partition sizes.
    I will consider it, if anyone can steer me to a good and reliable off-site backup system that allows me to store my data just for a few hours. In that case I could move all data off drive hda and repartition the drive completely. However, wouldn't that cause problems with fstab and mtab data upon re-installation?
    I want to include hda3 into the extended part. Then
    Re: Partition problems again - and running out of space soon
    Long time waiting -- no reply.
    You asked for "detailed steps", but it strikes me you need to step back and maybe consider the bigger picture first. You are trying to squeeze the last 3% out of this 60GB hard drive with a revision of this particular partitioning scheme, with no backup method available for your valuable data, and yet
    So, you're running 2 hdds, and some multiple number of OSs. What is your real objective with this system, over the longer term? Why are you so intent on cramming this hdd full to the point that there is zero growth potential? I'm sure you know that large hard drives are available for USD $0.32 per gigabyte:
    http://www.newegg.com/Product/Produc...82E16822136053
    So, if I were you and had the problem that you described, I would buy that 320GB WD hard drive, plug it in to my system in lieu of whatever the second hard drive is that you didn't tell us about, and boot a GParted Live CD obtained from here:
    http://sourceforge.net/project/showf...kage_id=173828
    I would partition my new drive appropriately for whatever my purpose was, maybe make a "My Data" partition on it that all my OS's could access, then copy the valuable stuff into that, and then proceed to reconfigure my system to suit my plan.
    As far as relieving your immediate crisis for the VERY short term, make a swap partition on your other hard drive, edit /etc/fstab to use the new swap partition, then you can delete /dev/hda4 on this drive, leaving you with only 3 primary partitions on this overburdened drive, and a wee bit of flexibility to adjust the remaining partitions such that, at the end of moving them all, /dev/hda1 gets to add both the 300MB and the 1.9GB from /dev/hda3.
      For immediate space issues, you can try clearing the package cache of old packages:
      sudo apt-get autoclean
      or all packages
      sudo apt-get clean
      The package cache (/var/cache/apt/archives/) can amount to quite a bit, especially after a full version upgrade.
        or all packages
        sudo apt-get clean
        Will probably help a bit but I have to also agree with dible. Get yourself a new HD make a separate data partition. This makes sense for a lot of logical reasons not the least of which is data safety
        I went through the same ordeal not to long ago so I feel for you.
        A word of reason. Before starting I would get to know all I can about uuid's (there is plenty about that here on this forum) and your fstab editing.
        Repartitioning / moving partition and or resizing / merging, etc will definitely screw up your fstab, /boot/grub/menu.lst and corresponding uuid's.
        Just a few questions:
        How much data would you be moving / saving / backing up?
        Can't you burn a few Data DVD's?
        For online data storage you can use this:
        [url=http://[url=http://www.xdrive.com/]http://www.xdrive.com/]http://www.xd...drive.com/</a>
        the first 5Gig are free.
        A further suggestion would be to get aptoncd:
        http://aptoncd.sourceforge.net/
        and use that to backup all the apps on your main linux (before you upgrade) so you can do a fresh install of your current system after do your partitioning fun and reinstall all of the apps you had before. That will keep you from spending a lot of time getting your menu.lst, fstab back in oder.
        As for a step by step there is a lot of very good documentation on the gparted link dible gave you. Have a look there as well.
        As far your partitions are concerned leave one primary (for your main linux) and change the rest into logical partitions. You can do this with gparted as well.
        I hope this helps you along a bit.
        4 GB Ram
        Kubuntu 18.10
          dibl -
          kubicle -
          Fintan -
          Thank you all for your prompt and valuable replies. I will use them to resolve this problem.
          As usual, I did assume too much, i.e. I sort of expected you guys to know what I did not mention in my post;
          I have 2 HD because I used to dual boot Linux and Windows.
          My Linux drive has Dapper Drake and Gutsy as OS.
          The former Windows drive has another Gutsy, up-to-date and working beautifully..
          Most of the partitions on the drive do not hold a lot of data., except for the (ex - Windows) partition hda1.
          The ultimate solution is what dibl suggested.
          Temporary fix:
          How about backing up/saving all data on hda to CD or offsite/remote backup and Then a format, re-partition of hda before clean installation of a copy of Gutsy?
          That should eliminate the fstab confusion.
          Correct?
          Any suggestions for offsite backup?
          I know of Carboncopy (Windsows only)
          Tried rsync (without real success).
            I managed to resolve the problem along the lines of the suggestions above. thanks again for contributing.
            Here is how I did it:
            I finally remembered that I can upload data to our host server.
            Uploaded all data files to server via ftp.
            Used fdisk (on Freedos) to repartition hard drive number 1 with only 2 new partitions..
            Gparted to format partition.
            Re-installed Kubuntu 7.10 (after fresh download of image) as a clean install.
            Downloaded data files to the second of the new partitions.
            Everything is working just fine now. this is essentially a variation of dible's suggestion.
            Next, I will do the same to hard drive 2 -except that I will re-install Dapper Drake, which I keep as the always working, always reliable fallback in case the adventures with 7.10 hit a sang.
            Thanks again.
