gutsy will not load
    gutsy will not load
    Hi all
    i am having problems,now i am not sure if the problem lies here,
    before upgrade i had ubuntu fiesty fawn 7.04,with kubuntu fiesty fawn desktop,
    when i did upgrade i did it while in ubuntu .
    when re-starting pc,i get this error
    busybox v1.1.3/debian 1.1.1.3-5ubuntu7 built in shell (ash) .
    i can however go to grub,and boot into ubuntu fiesty and also choose kubuntu desktop.
    in fiesty,i have the little green running man and some other gusty stuff
    in kubuntu desktop i have updates ready to be installed,i check what updates and its gutsy 7.10.
    i have left a post on the ubuntu website,no1 seems to be able to help.
    i am not sure if i should be leaving this q here,sorry if i am on the wrong site as i am so confussed
    thanks
    Re: gutsy will not load
    Just a rough guess, but did you try to install the Kubuntu updates? Did they work?
    And don't worry about being confused. That's how you know you are running Linux.
    I wish I was the man my dog thinks I am.<br /><br />Registered Linux User No. 402825
      Hey thanks so much for a reply
      no,i have not installed the kubuntu desktop update,should i ?
      i only did ubuntu upgrade to gusty
        OK
        i tried the upgrade,it starts then tells me my system is up to date
        i am so confussed
          Are you still getting the "busybox error"? How far does your system go when you boot?
            yes i still get busybox error
            i boot up and the kubuntu splash screen comes up,then i wait and then busybox error comes up
            thanks
              it looks as no1 has any fixes for this,it must be a bug,how do i summit a bug report ?
