Items in KMenu and wireless and compiz
    Why does everything in my KMenu in my fresh gutsy beta install have (Items in K Menu) in front of it...will the go away with the final release?
    Also...wireless doesn't work in this...works fine in Feisty (feisty calls wireless rausb1, gutsy calls it wir1).
    No deal breakers yet cause it's beta, but no wireless makes it impossible for the new release.
    had to reinstall feisty anyway cause the update gave me a black screen on boot-up after installing compiz-kde
    Re: Items in KMenu and wireless and compiz
    1. Known bug. They're working on it last I heard.
    2. My wireless didn't work either after upgrading. had to reconfigure my Network Connections (in KNetworkManager or System Settings). After that it worked ok.
    Jucato's Data Core
      I tried reconfig same as i have to with feisty (automatic, dhcp, network, start on boot, default gateway) it doesn't remember the default gateway, very odd. i'll have to try it again after final release...wifey is mad cause she can't facebook for the past 2 days :P
