note: flash works, vid works on youtube just no sound.
Why is it that the same install dvd w/ same hw doesn't do the same thing it did 2 months ago.
2 months ago it took some configuring in dapper to get opical output working. switched to gutsy no optical no matter what, gave up went w/ analog. no problem right out of the box.
tried a few other flavors, now my agp isn't recognized out of the box and I have to physically remove it to instlall gutsy again. try to reinstall it, no luck still using onbaord. tried a few more flavors no sound support out of the box.
back to gutsy no sound supoort out of the box.
What gives here?
I've added medibuntu, done
tried adding alsa, adjusting kmix, btw this install had startup sound, now it doesn't even have .flac support.
I'm sure I've tried a dozen other things, can anyone help before I rip my hair out?
I do have an old yamaha usb 2.1 system out in the garage, any chance it will install itself plug and play?, I'll sell the 5.1 spkrs and soundcard if it did just had surgery so I will have to wait a day or two to dig it out.
What gives here?
sudo apt-get install kubuntu-restricted-extras
