I have managed to screw up my wireless setup (it was working fine until I stuffed something up yesterday). Running iwconfig gives the following in the relevant entry
I believe the problem is related to the 'radio off' but I can't figure out how to change this to radio on. Anyone know where I can do this?
I installed kwifimanager (in case the prob was with knetworkmananger) and under its file menu it has an entry 'radio disabled' that is selected but unfortunately I can't turn it off here.
eth1 radio off ESSID:"linksys"
Mode:Managed Frequency:nan kHz Access Point: Not-Associated
Bit Rate:0 kb/s Tx-Power
ff
Retry limit:15 RTS thr
ff Fragment thr
ff
Power Management
ff
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:19766 Missed beacon:0
Power Management
