Ethernet Connection doesn't work if cable is connected AFTER boot
    Hi, this is my first post here. I have this problems with kubuntu.
    If I connect the ethernet cable AFTER the boot up the ethernet interface doesn't work and there is no way (for example ifconfig) to make it work.
    If I start the OS with the cable already connected there is no problem and the DHCP works perfectly. What is the problem?
    My Notebook is an Acer Aspire 9420 with Kubuntu Feisty Fawn.
    Tell me if I have to post other infos, i'm totally a newbie. And Sorry for my poor English
    thx
    Re: Ethernet Connection doesn't work if cable is connected AFTER boot
    How about sudo /etc/init.d/networking restart ...?
      No way. Here is the output on the terminal:
      * Reconfiguring network interfaces...                     There is already a pid file /var/run/dhclient.eth0.pid with pid 4366
      killed old client process, removed PID file
      Internet Systems Consortium DHCP Client V3.0.4
      Copyright 2004-2006 Internet Systems Consortium.
      All rights reserved.
      For info, please visit [url]http://www.isc.org/sw/dhcp/[/url]
      Listening on LPF/eth0/00:16:d3:4e:be:8c
      Sending on  LPF/eth0/00:16:d3:4e:be:8c
      Sending on  Socket/fallback
      DHCPRELEASE on eth0 to 10.0.1.6 port 67
      send_packet: Network is unreachable
      send_packet: please consult README file regarding broadcast address.
      There is already a pid file /var/run/dhclient.eth1.pid with pid 4394
      Listening on LPF/eth1/00:18:de:6e:46:9b
      Sending on  LPF/eth1/00:18:de:6e:46:9b
      DHCPRELEASE on eth1 to 10.0.1.6 port 67
      There is already a pid file /var/run/dhclient.eth0.pid with pid 134993416
      DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 6
      DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 9
      DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 12
      DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 4
      No DHCPOFFERS received.
      No working leases in persistent database - sleeping.
      There is already a pid file /var/run/dhclient.eth1.pid with pid 134993416
      DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 3
      DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 5
      DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 8
      DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 11
      DHCPDISCOVER on eth1 to 255.255.255.255 port 67 interval 4
      eth2: ERROR while getting interface flags: No such device
      There is already a pid file /var/run/dhclient.eth2.pid with pid 134993416
      SIOCSIFADDR: No such device
      Bind socket to interface: No such device
      Failed to bring up eth2.
      ath0: ERROR while getting interface flags: No such device
      There is already a pid file /var/run/dhclient.ath0.pid with pid 134993416
      Failed to bring up ath0.
      wlan0: ERROR while getting interface flags: No such device
      There is already a pid file /var/run/dhclient.wlan0.pid with pid 134993416
      Failed to bring up wlan0.
                                           [ OK ]
        try:
        sudo ifdown eth0
        then
        sudo ifup eth0
          Maybe this applicantion help you: http://0pointer.de/lennart/projects/ifplugd/
            ifdown eth0
            then
            ifup eth0
            you must use sudo so:
            sudo ifdown eth0
            sudo ifup eth0
            ----- eth0 is the ethernet card listed in if config
              if you do ifconfig eth0 down/up, afterwards, you might (or might not) have to kill and rerun dhclient. That's more or less what I had to do in archlinux, but then again archlinux uses dhcpcd instead of dhclient.
              Maybe going to knetworkmanager, configure manually, and disabling/enabling eth0 in that dialog could help...?
