Re: Problem starting Kubuntu
You are welcome
That just means you have to deactivate your internet connection.
Which also means you will have to install without language packages (Spanish, etc) then install them (language-pack) from your installed Kubuntu and set the languages by hand which is not difficult and maybe a theme for a different post.
You are welcome
Taking the system offline works
