ALTGR not working and c cedilla not possible
    I daily have to write French and German,
    which means my freshly installed Kubuntu Feisty is rather useless.
    1 When I type '+c it doesn't give the usual ç, yet an ć
    2 Moreover, the right ALT key doesn't do anything. Which prevents me to type ß euro sign etc, etc,
    3 Finally, the left ALT + keyboard number doesn't do anything either (numpad enabled of course)
    KEYBOARD Layout settings now are as follows
    US English international alt
    Seems I am stuck with the limited english alphabet.
    Please help !!! thanks in advance.
    Re: ALTGR not working and c cedilla not possible
    I had the same problem with the Euro sign, but I resolved it yesterday, see: €!!! (Right Alt + 5 ).
    If you go into System Settings -> Region and Accessibility (in the Personal section) -> Keyboard Layout, you'll see 3 tabs. You'll need the Xkb options.
    Activate Xkb options and select a 3rd level chooser, eg. right ALT, as well as a key to bind the Euro sign to, e.g. 5.
    It should work then.
    I' m running a dutch Kubuntu, so maybe I have the English names not quite right, but you should be able to find this.
    I can't help you with the c cedilla, I get the ć as well.
      I don't know about us keyboards but if you go to system settings->regional->keyboard layout you can add regional keyboards like german, french or whatever. Then you can add a language chooser to the panel / quick starter:
      [Alt][F2]kdesu qt-language-selector
      4 GB Ram
      Kubuntu 18.10
        My problem was the opposite - being able to compose all sort sof accents I didn't need... I think there are several overlapping mechanisms in use to support composing accented characters and it's a bit of a maze.
        I wanted to suppress 'deadkeys' method of composition, which seemed to be the one that was in use, but it's not well documented. Perhaps if you want to get c-cedilla, then you can use
        , + c
        not
        ' + c
        as you have tried. I am not at my Kubuntu box now, so can't test it, but I was able to use , and ' to form accents, I think.
        Miles
