Hello,
I want to try Kubuntu 7.04 on an old Pentium MMX CPU, with 262 Mb of memory. The LiveCD that I use starts correctly on my Pentium 4, with 1 Gb of memory. On the old Pentium MMX CPU I can run correctly a LiveCD of Puppy 2.16
The problem that I have is that the LiveCD with Kubuntu 7.04 start booting, load the kernel, displays a lot of steps taken with an oke flag, but stops after the step "Starting Advanced Power Management Deamon". The CD-Drive is constantly reading the LiveCD but after more than a hour no progress with a completed next step. So I powered the CPU down.
Is there a way to see what the problem is?
Have somebody experienced the same problem and what was the solution?
Regards, Frans
Regards, Frans
