Hi everyone,
I know, that this topic is already in the forum at last a couple of times, but, I tried all the solutions, and doesn't work any of them.
I tried with edit "/etc/kde3/kdm/kdmrc" and edit the lines
* HaltCmd=/sbin/shutdown -h now
* RebootCmd=/sbin/shutdown -r now
* TerminateServer=true
I tried too, from the console with:
* sudo shutdown now
And I tried too, to edit the menu.lst and add "acpi=off apm=power-off " in the line that start with "kernel ..."
None of those work, any idea?
I just installed the Kubuntu yesterday, and the only thing that I did, was update the files... but... the problems with the shutdown and reboot was allready when I just finished the installation.
Thank you.
* sudo shutdown now
Thank you.
